By captainOCD - Sun Aug 30, 2020 1:28 pm
#13322
Since my blue car has been painted and aside from a few exterior cosmetic things that still need touched up and some more interior reupholstery, it really doesn't need much attention aside from driving right now. That combined with the pandemic has left me bored and I've started messing with the tan car now.
Since it's been a while since I've posted about it, I bought it in 2018. I did a timing belt/water pump job, replaced all fuel lines, put on new coolant hoses, made a new engine harness for it, serviced the trans, got the brakes to work, and repaired a host of wiring issues inside and in the engine bay. Currently it runs, goes, and stops. It is currently idling high, around 1200-1800rpm depending on the mood it's in.
After about 5 -10 minutes of running at idle it's showing the needle just under the orange mark on the dash. I've just shut it down at that point. So far I've replaced the inner thermostat seal, the new thermostat (that tested working) with another tested working original from the 84 parts car. I also flushed out the whole cooling system a couple months ago first with the garden hose then did the final flush with distilled water. Nothing seemed blocked including the radiator.
Initially the car was facing uphill and then had the front on ramps on top of that. I lowered it back down to the ground to see if that would help and it didn't. I've tried pulling a vacuum on the cooling system and letting it suck in coolant as well (my blue car didn't seem to have trouble bleeding air). Also tried massaging hoses.
I was kind of doubting the gauge, so I checked with the infrared gun. Water bridge is measuring about 205f when the gauge is still a bit below the orange. Radiator upper hose is around 185-190 and lower is about 175-180. Radiator gets hot, was measuring around 170 where I could get to it. I didn't have the balls to let it run much past that point though.
To me it seems odd that if I leave the cap on the expansion tank, the hoses never get firm. Hot, but not firm. With the cap off it doesn't seem like much expansion occurs either. Starting the motor does bring down the temp some if left to heat soak for a few minutes, so water is flowing. That said I am wondering in the back of my head about pump efficiency. The block did have some scoring from a previous impeller hitting it. I didn't think much of it at the time having only been 2 weeks into 928 ownership. The pump on it was fine though, so presumably it was working like that for a while.
So I do have a new temp sender on the way, but chances are it's not gonna tell me anything different. Anyone have any thoughts here where to look next? I'm gonna take my blue car out in a bit for a drive and plan to measure various parts of it's cooling system and see how they compare to the tan car.
-Matt
-84 928S auto - parts car
