By WyattsRide - Mon Aug 31, 2020 11:24 am
#13545
I've been experiencing this lately. When the engine is hot (not overheated), slowing to a stop and taking it out of gear. The idle surges ,drops real low and then stalls.I may even hear a low backfire when I get out of gear. It will sometimes start right up and idle. Or if it keeps stalling, I'll have to have the clutch pressed in, start it, put it in gear and go. This does not happen in normal driving times. Even when the engine is up to temp. It seems it takes a lot of driving for it to happen.
Example Saturday. Did some very spirited driving for the first 60 miles. No problems when coming to a stop, parking etc. It sat parked for about 45 mins. On the way home we did some more high speed driving for another 60 miles. But coming into town and having red lights and stops, the stalling and rough idle problems started. I really had to baby it the last 10 miles of starts and stops, until I could drift it into my driveway.
Before yesterday, I removed and tested the ISV that I replaced in 2014. About 12k miles on it. It tested (I think) fine with a 9v battery. Clicking open and close quickly. Sprayed it with a little WD40, even though I'm not sure that trick works on a 85 MY ISV before I put it back in.
What else can I check before driving to Frenzy at the end of Sept?
Note:
ISV is a Bosch
Short harness TPS and MAF was also replaced in 2014
(I posted this same question at RL 928 board)
Note:
ISV is a Bosch
Rick
1985 Schwarz/Burgundy / 5-speed /X-Pipe and no Cats
"Porken S300s Chips, Dips, Chains and Whips. You know, your basic HS orgy type things" - Lisa (Weird Science)
Rick
