By maddog2020 - Wed Feb 23, 2022 9:21 am
#135548
There are 2 different 928 cam tool sets. there is the 9226 which comes with the saddles to bolt the cams down, the threaded studs that allow you to bolt them down to the heads and a couple of plates to time the cams. These are documented for the early 32v engines, and then there is the 9248 which are just the saddles, and are supposed to be used on the S4 and later engines.
do the early 32v heads have different cam spacing than the S4 and later heads? I've never had one of each to compare
