By SidViscous - Fri Jan 07, 2022 11:31 pm
#127042
Hmmm noticed we don't have a wrenching/wrenching tricks forum.
Well as you all probably learned at some point, when doing a brake bleed one person working the pedal, other doing the down - up - down - up - down business. just like sex, including the brake fluid.
But, requires another person. Somewhere here or t'other plaice. I talked about a setup I had done with a bottle that has a magnet, some tubing and a one way valve.
Turns out all that business is extranous, all you need is some tubing. I used some surgical tubing I had around. Used enough to go from the nipple, straight up over the wing mirrors (In the back just went up about as high and tucked it into the gap in the door frame, and then back down into a bottle. The steep up climb lets bubbles rise quickly. If you pump enough it just turns the corner and goes into the bottle. Crack the valve a little. Get in, pump it a few times until you think your done, check that there is a goodly enough amount of fluid in the tubing. Tighten the bleeder valve. Check pedal feel. If it's good. Then just pinch of the tubing near the nipple, hold it up high and pass the tubing through your hands until the excessive fluid drains out.
Done, quick and simple.
______________________________________
Pinochet Aviation club BSC, SSC.
Peace at the cost of free will. I'll take war every time.
2 parties is definitely not enough, 3 is far too many.
At least David Carradine died doing what he loved.
