#116382
So I'm thinking of replacing my Blaupunkt Bamberg (uses the stock 928 audio harness with DIN to the Fosgate amp) with a slightly newer Wiesbaden which uses the more modern Blaupunkt plugs.
Speakers are not an issue as I will run RCA cables to the amp, but is there a socket that can fit the older style power/ground/antenna/light harness on the 86 928S?
Thanks!
Chris
If these folks don't have what you need they can probably supply the components for you to DIY the adapter you need:
https://www.bergvillfx.com/categories/wiring-harnesses
if you still have the original radio connector on the cars wiring loom you need Porsche's adaptor loom 91164240000 to fit onto all modern radio's.
