By JBRob007 - Mon Aug 09, 2021 6:20 pm
#96960
On my 2000 996 the conv top deploy & retract switch on the dash used to work just fine. One day I used the key in the door lock open/shut method and now the dash switch no longer activates the top… up or down. The button works because the dash light now blinks quickly four times, a relay clicks behind the driver seat, and the light cycles through again but nothing happens. It’s as if something is ajar and prohibits the top from moving and the system senses an obstruction. The only problem is the key method of opening/ closing still works just fine. I know it won’t deploy if the engine cover is open or the E brake is off. Cover is closed and E brake is on… still no luck from the dash button. The owner’s manual has no information on the cause or what the blinking light means… much less fuse / relay locations.
Any ideas where to look for a cause?
Bad relay and if so where is it and how to get to it?
Engine cover micro switch may be bad and if so where is it located?
Thanks! Joel
Thanks! Joel
Joel Roberts
Vice President, 928 BuckeyeLandsharks
Saving your 928 for the next owner is like saving your girlfriend for her next boyfriend... it's crazy!!
