Regarding winterizing.........
Posted: Wed Oct 14, 2020 11:01 am
Since it seemed to be an annual topic on the other site, here's what I do to winterize my cars for approximately 6 months of storage:
- Wash and thoroughly dry the car (so I don't have to do it in the Spring)
- Oil/filter change immediately prior to storage (you don't want to leave "used" oil in during extended storage - used oil can be somewhat acidic )
- add a bottle of Stabil and fill the gas tank (a full tank avoids condensation forming in the tank)
-pump tires up to 50 psi and let the car sit on a piece of carpet remnant or tire cradles (don't put the car on jack stands unless you place the stands under the suspension. stands under the frame can potentially cause issues - the suspension is designed to hold the weight of the car).
- connect a battery tender/maintainer (do not use a trickle charger - they will overcharge and fry your battery over long periods of time)
- use your favorite rodent-deterrent method, if necessary.
-cover the car (optional)
- Lastly, do not periodically start the car unless you can let it run up to full operating temperature. Starting it and running it for short periods only creates condensation in the engine and exhaust system.
I've been doing these simple steps for many years and they always start right up in the Spring with no issues.
Cheers.
Cheers.
