Guts (Peaking Under the Covers)
Posted: Fri Nov 21, 2025 7:03 pm
by hernanca
I've thought of a thread like this for a while.
Sometimes I just want to visually see how some 928 part is put together or how it looks inside. Post pictures here for those ocassions that something 928 is sitting disassembled in all its glory in front of you or was unfortunately destroyed to reveal it's insides.
I have a couple, here's the first one: 87+ side molding. I bought some used ones to see if I could create a pseudo GTS rear fender side molding tip (NLA). I needed to see what they were made of, so I cut one in half - looks like it is flat metal stock plus rubber?:
Re: Guts (Peaking Under the Covers)
Posted: Sat Nov 22, 2025 12:18 pm
by h2pmr
innovative idea for a thread
pictures below from the photo thread from a while ago of the innards of the carbon canister under the front fender
Posted: Thu Dec 04, 2025 4:46 pm
Posted: Fri Dec 05, 2025 4:16 pm
by h2pmr
if you have had a door card off an 87+ model and wondered what the indentation marks are for next to the interior light, they are for the coin holder.
have seen the indentation on all the door cards i have removed but you don't see many coin holders, and what they look like from behind
Posted: Fri Dec 05, 2025 4:21 pm
by h2pmr
door skin around mirror mounting is certainly sturdy
and fingers crossed will get a new avatar on Sunday.....
Posted: Tue Dec 09, 2025 5:10 pm
by linderpat
Good thread. Here's one - oil sender.
Posted: Thu Dec 11, 2025 11:14 pm
by hernanca
Posted: Sun Dec 14, 2025 2:32 pm
by h2pmr
the innards of a cruise control actuator, removed from the 87.
Posted: Sun Dec 21, 2025 11:05 am
by h2pmr
rear seat frame from i think an S2
Posted: Sun Dec 21, 2025 3:13 pm
by hernanca
Posted: Fri Jan 02, 2026 12:03 pm
by hernanca
1981 928 headlight squirter:
(black plastic was cut in half-ish)
Posted: Fri Jan 02, 2026 3:53 pm
by h2pmr
inside a rear speaker crossover unit 92864544100 and its now in the trash
Posted: Tue Jan 06, 2026 3:23 pm
by h2pmr
rear tow eye mount unbolted from the cross beam.
that's how far it goes when fully screwed in
Posted: Mon Jan 19, 2026 5:01 pm
by hernanca
Posted: Sun Feb 01, 2026 2:55 pm
by h2pmr
the insides of the throttle switch, white "3789" is the switch you hear click
Posted: Tue Feb 24, 2026 2:34 pm
by h2pmr
internal cross section of the front suspension spring top mount 92834304708
Posted: Sat Mar 07, 2026 3:46 pm
by h2pmr
inside the aerial amp for those with the aerial in the front screen
not Porsche's best idea
rule 1 for best results keep it as simple as possible
Posted: Sat Mar 07, 2026 7:45 pm
by N_Jay
h2pmr wrote: ↑Sat Mar 07, 2026 3:46 pm
First time around German cars?
Posted: Sun Mar 08, 2026 5:00 am
by h2pmr
N_Jay wrote:h2pmr wrote: ↑Sat Mar 07, 2026 3:46 pm
i have been around these Porsche's for the past 20+ years, but am used to the odd concepts that motor motor manufactures sometimes have as i have worked on French cars for the last 40+ years in the day job.
Posted: Sun Mar 08, 2026 6:29 am
h2pmr wrote: ↑Sun Mar 08, 2026 5:00 am
... as i have worked on French cars for the last 40+ years in the day job.
Ah. That explains a lot.
Posted: Sun Mar 08, 2026 12:32 pm
by N_Jay
Just kiddiung around, but it does seem if there is a way to add complication, the Germans find a way.
Posted: Sat May 30, 2026 3:23 pm
by h2pmr
inside a dim dip headlight control unit, just a short lived UK / European requirement to have 50% dip headlights on when just the sidelights were turned on and engine running
Posted: Sat May 30, 2026 3:44 pm
by h2pmr
inside a headlight height adjuster motor, sadly the main shaft that connects to the headlight was broken, so was going in the bin anyway.
Re: Guts (Peaking Under the Covers) UBJ
Posted: Tue Jun 02, 2026 1:29 pm
by Scoper
Posted: Tue Jun 02, 2026 2:10 pm
by hernanca
^^^^^ early aluminum original or steel replacement?
Posted: Fri Jun 05, 2026 3:34 pm
by Scoper
That is of the upper BJ. The lower one was aluminum in early cars and should be placed by steel versions. Just did them too!
Posted: Sun Jun 28, 2026 4:45 am
by h2pmr
rear spring rubber mount 92833304301 fits all model years.
nice to see the rubber is bonded to the metal tube all the way up, so no chance of water / rust getting in
if you make something right in the first place, why change it.
