another gas tank sender unit
Posted: Mon Nov 03, 2025 3:32 pm
by h2pmr
this one was removed from the 87 i broke, was going to stick it on ebay but i does not sit straight.
thought i would gently heat the plastic bowl to get it straight but the issue is the original mounting hole is not in the middle, so i guess its been like that since new.
anybody seen that before ?
Re: another gas tank sender unit
Posted: Mon Nov 03, 2025 5:58 pm
by maddog2020
take it off and drill a hole in the center? the washer is large enough to cover both holes.
Posted: Mon Nov 03, 2025 6:03 pm
I don't think the hole being off-center has anything to do with the cant of the assembly: something's warped.
Posted: Mon Nov 03, 2025 6:51 pm
by smiffypr
Looks like the plastic may be warped, but that is not part of the sensor, so sell it without the plastic.
Posted: Tue Nov 04, 2025 2:43 am
by h2pmr
thanks gents, i will drill another hole in the middle + see if it will heat and straighten.
Posted: Tue Nov 04, 2025 3:43 pm
by h2pmr
hole now in the middle + a touch of heat from a hot air gun and now sorted :thumbup:
