Clean Oil Change Hack
Posted: Fri May 16, 2025 12:56 pm
Maybe there is a market for 3D Printed "oil filler adaptor caps"
N_Jay wrote: ↑Fri May 16, 2025 12:56 pmWonder what condition the Shop Vac is in after he's done.
fpena944 wrote: ↑Fri May 16, 2025 2:47 pmYou are not pulling any oil out the top.N_Jay wrote: ↑Fri May 16, 2025 12:56 pmWonder what condition the Shop Vac is in after he's done.
I bought a pump that I use with my small gas engines but haven't considered using it on the P-cars yet.
Last week I changed the oil on the Cayman and it was the cleanest one I had ever done. I think I got it figured out now (3rd time is a charm!) as it is a bit tricky since suspension pieces get in the way of removing the filter.
The 996 and Cayenne are easy though. On those two the filter is fully exposed and simple to remove without a mess.
N_Jay wrote: ↑Fri May 16, 2025 3:02 pmAh ok I get it now.fpena944 wrote: ↑Fri May 16, 2025 2:47 pmYou are not pulling any oil out the top.N_Jay wrote: ↑Fri May 16, 2025 12:56 pmWonder what condition the Shop Vac is in after he's done.
Just adding some vacuum so you can get the plug out and you hand out of the way, before you shut off the vac and let the oil drain.
