washer bottle level sensor
Posted: Thu Feb 06, 2025 3:40 pm
probably a pointless thread but am interested in the obscure things fitted to a 928 and how they work
fitted to the main washer bottle is a level sensor, i had a spare one from an 87 so thought i would test it on the bench.
multi meter set to ohms and got open circuit when connected to both of the terminals with the float in any location.
but when moving the float by hand can hear a very faint electrical click noise when the float roughly passes the half way mark, does it every time
i did try it in a cup of water and moved the float up and down with a small screwdriver and it did get continuity a couple of times but mostly still got nothing
so removed the float
could see nothing so gently cut it in half and removed the bottom section of it.
metal shaft runs down the middle and connects to the "switch" which is connected to one terminal on the top.
red wire runs with it and connects to the other side of the "switch " which is connected to the other top terminal
float itself is a light as a feather but must have tiny magnets in it.
even now if i run the float over the "switch" it still makes the faint electrical click every time.
is it a type of mercury switch ?
