Rear End Refresh
Posted: Sun Nov 17, 2024 5:02 pm
by Crumpler
Subtitled: Adventures in shop pressing, best 400 bucks I ever spent.
All new bushings. Powerflex on all but the rocker bar and rear upper control arm.
My first question is this:
After you hang and press out the rear hub, the inner race of the bearing is attached.
There’s a special factory tool in WSM, but it looks like a plate you get under the lip and press hub off of it. I can fabricate one but there’s no space to work it in there.
What’s the move, without ham fisting the hub?
Re: Rear End Refresh
Posted: Sun Nov 17, 2024 5:09 pm
The “factory tool” is just a “bearing splitter.”
Easy google:
https://www.harborfreight.com/bearing-s ... 014710450d
Posted: Sun Nov 17, 2024 5:10 pm
Don’t forget that I posted a long thread (here) on doing the rear control arms.
Lemme see…
Posted: Sun Nov 17, 2024 5:13 pm
Posted: Sun Nov 17, 2024 5:48 pm
by Crumpler
Excellent resource!
No way I can screw this up now.
I had the pleasure of making an industrial strength metal jig, to hold the half axels on the bench. Because why plan ahead and loosen the rear axel nuts before you dismantle the car?
:kickbutt:
Posted: Sun Nov 17, 2024 6:07 pm
Crumpler wrote: Sun Nov 17, 2024 5:48 pm Because why plan ahead and loosen the rear axel nuts before you dismantle the car?
Same logic applies when you pull the engine: don’t worry about breaking loose the crank bolt. :hitfan:
Posted: Thu Nov 21, 2024 9:05 am
by linderpat
someday I'm going to have all of these jobs done, so that my 928 rides like a new one. :beerchug:
Posted: Sat Nov 23, 2024 5:50 pm
by Chaos
Based on the title…..way more than $20,000 let alone $400 I paid for someone’s front end refresh.
Posted: Sat Nov 23, 2024 5:58 pm
Thanks for polluting a technical thread. Really classy.
Posted: Sun Nov 24, 2024 9:11 am
by Crumpler
Chaos wrote: Sat Nov 23, 2024 5:50 pm Based on the title…..way more than $20,000 let alone $400 I paid for someone’s front end refresh.
:cool:
I’m just happy people are reading and posting !
I always wondered what a front end refresh costs.
Surely there are aftermarket options cheaper then 400 right?!
Posted: Sun Nov 24, 2024 9:18 am
by Crumpler
linderpat wrote: Thu Nov 21, 2024 9:05 am someday I'm going to have all of these jobs done, so that my 928 rides like a new one. :beerchug:
You know Ed, as I pull the factory bushings, I have to say most of them still seem fine. The rocker bar bushings were toasty, but the control arms and sway were pretty pliable and feel like factory rubber still. At least on this car.
I’m guessing the front bushes are more of an upgrade for overall feel?
Posted: Sun Nov 24, 2024 7:35 pm
by linderpat
I’m just thinking about what Gary did with his car. He said it was transformative. He did all the rubber. Maybe he’ll weigh in on this thread.
Posted: Sun Nov 24, 2024 9:18 pm
by Crumpler
Indeed. I should make a judgement after I drive it.
The power flex bushes are stiffer than stock, so it should feel different.
Some progress today.
Posted: Wed Nov 27, 2024 8:19 am
by Crumpler
Not the prettiest factory welds that day.
Posted: Sat Nov 30, 2024 9:28 am
by Crumpler
Hey guys, question:
Before I press anything…
Rear bearings (new) have shielding on one side.
Factory bearings (old) did not.
Are these unidirectional?
And which side towards the transmission?
I found an old RL thread, but sounded anecdotal.
Nothing in WSM so far.
Posted: Sat Nov 30, 2024 11:00 am
IIRC I put the metal shield on the transaxle-side because:
- better support for press piece when pressing-in hub
- outer inner race stays on hub when disassembled, so plastic shield makes it easier next time.
Having destroyed one of these new bearings (see second point above) and then examining the entrails, there is no physical difference side to side. My cynical side suggests that the bearing maker saved $0.005 by using the plastic shield on one side.
Posted: Sat Nov 30, 2024 1:19 pm
by Crumpler
Appreciate the support.
That sounds reasonable.
In full honesty, I committed the number two mentioned above yesterday. Not fully supporting the inner race while pressing the hub in. :banghead:
I was impressed how easily the bearings go in if you heat the carrier and freeze the bearings. Granted the shop press makes a huge difference.
I expected a rough time just from sheer bearing size.
Posted: Sat Nov 30, 2024 2:14 pm
Just remember: install the snap ring *before* pressing in the hub… :hiding:
Posted: Sat Nov 30, 2024 5:57 pm
by Crumpler
I’m overthinking this now, but hub is seated where I think it should be and sensor ring is not perfectly centered in window, with half axle loaded.
Normal, I’m hoping.
Posted: Sat Nov 30, 2024 6:14 pm
Crumpler wrote: Sat Nov 30, 2024 5:57 pm I’m overthinking this now, but hub is seated where I think it should be and sensor ring is not perfectly centered in window, with half axle loaded.
Normal, I’m hoping.
I’ve never looked down that hole. So, I can’t form an opinion.
If you’ve got room for the snap ring, then the bearing is seated.
When you crank down on the axle nut it may pull the 1/2 shaft in just a bit.
Compare with the other side and/or with the bits of your old bearing.
I suspect it doesn’t matter.
You need new CV boots.
Posted: Sat Nov 30, 2024 6:16 pm
Looking again… I don’t think the 1/2-shaft is fully seated.
Posted: Sat Nov 30, 2024 6:19 pm
Crumpler wrote: Sat Nov 30, 2024 5:57 pm ;… with half axle loaded.
Ok. So, you did have the axle nut cranked.
Posted: Sun Dec 01, 2024 10:48 am
by Crumpler
Dave thanks for following man.
I think I’m okay, pulling sensor on other side shows similar position of the ring while still at factory torque. The previous picture was nut at finger tight.
Looking at pic of the carrier before refresh, the hub was at same location as it is now.
Yeah, the boots are on the list. Sigh.
Posted: Sun Dec 01, 2024 12:15 pm
Crumpler wrote: Sun Dec 01, 2024 10:48 am Yeah, the boots are on the list. Sigh.
The boots are a “fun” job. Two cans of brake clean minimum.
Or, depending on condition/mileage, getting 2 rebuilt 1/2-shafts from Mark is a good option.
When the 1/2-shafts are 100k-mile plus I recommend that my client’s go the rebuilt route. Last time I checked Mark’s have new balls, etc.
Posted: Mon Dec 02, 2024 10:57 am
by Crumpler
How about this for fun…
5/8 aluminum plate jig, bolted through work bench.
8foot cheater, me on top of the car holding hub carrier with my feet. Sputtering curse word fragments.
Posted: Mon Dec 02, 2024 11:12 am
Crumpler wrote: Mon Dec 02, 2024 10:57 am How about this for fun…
You trying to get it loose? You need a 3/4” impact wrench with lotsa amps or lotsa CFM.
*Next* time you will loosen those when the car’s on the ground. That’s when jumping up and down on the cheater works.
:hiding:
Posted: Mon Dec 02, 2024 11:28 am
by Crumpler
Man, I’m telling you. I got a large impact set up but no dice on this one. Obviously not large enough.
Still would have needed the jig.
No I don’t think I will forget to loosen next time.
:hitfan:
Posted: Mon Dec 02, 2024 11:49 am
Crumpler wrote: Mon Dec 02, 2024 11:28 am Man, I’m telling you. I got a large impact set up but no dice on this one. Obviously not large enough.
:hitfan:
Induction bolt heater?
Posted: Mon Dec 02, 2024 11:55 am
by N_Jay
Get rid of ratchet for a breaker bar.
Run bar horizontal
Move cheater out about a 6 to 8 inches.
Load end of cheater with 150 to 200 LB (or a person)
Strike breaker bar with a metal face dead blow hammer or a good mallet.
Posted: Mon Dec 02, 2024 1:51 pm
by Crumpler
If you string certain curse words in the right order any torque can be broken Worf.
Yeah, heat used, couldn’t get horizontal because the stupid car is immobile and right next to the bench.
Anyway it’s done.
Posted: Mon Dec 02, 2024 2:00 pm
by N_Jay
Crumpler wrote: Mon Dec 02, 2024 1:51 pm If you string certain curse words in the right order any torque can be broken Worf.
Anyway it’s done.
Good to hear.
Otherwise was going to suggest you find some fatter friends.
Posted: Sun Dec 08, 2024 9:10 pm
by Crumpler
Posted: Sun Dec 08, 2024 9:43 pm
That’s looking good. You’re going to need new rubber grommet thingies for the ABS/BPW wheel well harnesses if you want them retained to the hubs in a stock-like manner. (And if you’re not buying new ones at ~450 each.) Jeannie has a bunch of sets in stock. They are not cheap but each a set does all four corners.
If this was a ‘proper’ restoration you’d want new ABS senders too. But those are stupid expensive for what they are.
Posted: Wed Dec 11, 2024 9:01 pm
by Crumpler
worf wrote: Sun Dec 08, 2024 9:43 pm That’s looking good. You’re going to need new rubber grommet thingies for the ABS/BPW wheel well harnesses if you want them retained to the hubs in a stock-like manner. (And if you’re not buying new ones at ~450 each.) Jeannie has a bunch of sets in stock. They are not cheap but each a set does all four corners.
Yes I was shocked (even for Porsche prices), they are stupid expensive.
Not in the works for this car. We will be making do for this stuff.
The harnesses from hatch floor to sensors is just terrible. Insulation is just gone.
Posted: Thu Dec 12, 2024 6:11 am
Crumpler wrote: Wed Dec 11, 2024 9:01 pm The harnesses from hatch floor to sensors is just terrible. Insulation is just gone.
For pre-‘90 (maybe pre-‘89.5) the ABS/BPW wheel well harnesses have that white braided nylon ‘stringer’ in the middle. That nylon shrinks with age, thus becomes shorter and cuts its way out of the insulation.
Cut that nylon.
Remove the ABS/BPW harnesses, replace and conductor sections showing exposed copper, and re-insulate.
So … that’s obvious. What’s not…
Install the harnesses on your suspension assembly before you lift it into the rear. That’s actually the reverse of the intended assembly procedure. That will also make it possible - or at least much, much easier - to figure out a way to secure those “restored” harnesses if you are not willing to spring for the ‘re-grommet’ kit.
Posted: Thu Dec 12, 2024 3:27 pm
by h2pmr
whats the part number of the rubber grommet things Dave ?
Posted: Thu Dec 12, 2024 4:09 pm
h2pmr wrote: Thu Dec 12, 2024 3:27 pm whats the part number of the rubber grommet things Dave ?
These are not Porsche parts. They are custom made bits. So no part number. They come in a set that does all the rubber harness retainers for all four corners. IIRC it’s 30 rubber retainers. Jeannie has inventory. I don’t know if they are on the website. About ~$300 for the set. Maybe less?
Posted: Thu Dec 12, 2024 6:19 pm
Looks like 18 bits to a set.
Here:
Posted: Thu Dec 12, 2024 7:37 pm
by Crumpler
Those are nice.
Thank you for the tip about cutting the string.
My primate brain was having some trouble with why the wire was longer then the string.
Posted: Thu Dec 12, 2024 8:40 pm
No worries. To clarify yesterday’s post: The ABS/BPW harnesses are supposed to come out with the rear suspension.
If you’d still had grommety grommets rather than the invisible ones you have now, the harnesses would have been retained properly and it would have been slightly more obvious that you disconnect them(*) in the battery box, push them out and then remove the suspension.
(*) And t-axle harness.
Posted: Fri Dec 13, 2024 2:15 am
by h2pmr
ah, thanks Dave.
very little chance of removing the ABS sensors without destroying them, so might remove these grommet things from this new S4 and put them on ebay.
thats if the old girl is as bad as i think its going to be and i decide to part it out
Posted: Fri Dec 13, 2024 10:56 am
h2pmr wrote: Fri Dec 13, 2024 2:15 am ah, thanks Dave.
The ABS sensors have nothing really to do with this. The sensors plug into these wheel well harnesses. The rubber retainers (grommets) are on the WW harnesses.
h2pmr wrote: Fri Dec 13, 2024 2:15 am so might remove these grommet things from this new S4 and put them on ebay.
:lol2: Would you cut a timing belt to remove it and then sell it on e-bay? (I know you wouldn’t.)
And it’s also clear that you’ve not really thought, yet, about these retainers.
But, you’ll figure it out.
Hint: if the retainers are all still rubbery, then you have a replacement WW harness that is less than 10-ish years old and you should (attempt to) sell the whole harness… if the casing is still ok.
My observations:
- the new WW harnesses appear to be made from better more-modern materials.
- only the ABS/BPW/RDK harnesses are available (right now) for all four corners. but they will work for all 86.5 - 95.
Posted: Fri Dec 13, 2024 1:16 pm
by h2pmr
ah yes these are on the actual wiring loom and not the ABS sensor, i had just fitted an ABS sensor to another make of car in my day job and it had similar rubber mountings along the length of the ABS sensor/harness itself
but surly if you can get new ones to fit onto the loom, you can remove the old ones from an old loom even if you have to destroy the old loom
need to have a look at this S4 this weekend
Posted: Fri Dec 13, 2024 2:05 pm
h2pmr wrote: Fri Dec 13, 2024 1:16 pm … if you can get new ones to fit onto the loom, you can remove the old ones from an old loom even if you have to destroy the old loom …
Umm… yeah. Sure. :hiding:
Four words:
Old Knock Sensor Connectors
Posted: Fri Dec 13, 2024 3:27 pm
by h2pmr
worf wrote:Four words:
yes i suspect they might fall apart in my hands when trying to remove them but i will give it a try.
will start a new thread on the one i am collecting tomorrow and will post the outcome on there
don't want to send this thread off topic to far.
Posted: Tue Jan 21, 2025 3:22 pm
by h2pmr
had a spare 5 mins, original patina FOC but still pliable'ish :drink:
Posted: Tue Jan 21, 2025 5:22 pm
Well, that there -^ is some luck.
