Fuel tank level for alignment
Posted: Thu Jun 06, 2024 9:05 am
by maddog2020
What is the consensus for alignments? Fuel tank full, half full?
Re: Fuel tank level for alignment
Posted: Thu Jun 06, 2024 9:34 am
by Schocki
According to the technical specification booklet the tank has to be full, spare wheel and took kit in the trunk too (DIN 70020).
Posted: Thu Jun 06, 2024 11:00 am
And if you want it ‘perfect’ weight equal to your(*) fat ass in the driver’s foot well.
* The Royal ‘You’, as in, not *you* but all of us except for those of us that couldn’t stand to lose a few pounds, in which case they can be offended.
Posted: Thu Jun 06, 2024 8:58 pm
by maddog2020
I was on my way to fill up today, and my 2 year old Bosch 044 pump died enroute, leaving me stranded on the side of the road. After getting flat bedded back home, I plugged in the laptop, and found that fuel pressure was a measly 27psi and it was running very lean, so I decided to upgrade to an AEM pump that is a higher output and is E85 compatible. I'll have to re adjust my fuel pressure regulator but I should be back on the road tomorrow, I hope. I have an alignment appointment on Wednesday.
Posted: Fri Jun 07, 2024 12:27 am
maddog2020 wrote: Thu Jun 06, 2024 8:58 pm … my 2 year old Bosch 044 pump died enroute, leaving me stranded on the side of the road.
Have you upgraded the wiring to it? Or is it still the stock wires?
Posted: Fri Jun 07, 2024 12:32 am
by Schocki
Is there a need to upgrade?
Posted: Fri Jun 07, 2024 8:37 am
by maddog2020
worf wrote: Fri Jun 07, 2024 12:27 am
Yes I upgraded the wiring and put a fused relay in the hatch area that is directly powered by the ECU.
Posted: Fri Jun 07, 2024 2:37 pm
by hans14914
The factory wire diameter is indeed too small to support the original 044 pump. Its borderline for the more efficient newer FP200-7 model.
https://www.bosch-motorsport.com/conten ... 93195.html
As sterling suggested, there are more efficient drop-in aftermarket pumps from both AEM and Deatschwerks that fit the cradle and are modern fuel compatible.
It is claimed the new Bosch pump is more compatible, but has reduced life with ethanol/oxygenated fuel. It draws approximately 9.5a of current at stock pressure and 13.5v. In a standard forced induction application of 12psi, the pump draws approximately 11.5a.
Flow at that point is around 310lph, which is a bit lower than some would want for a margin, but it falls within the electrical parameters of the stock wiring.
Posted: Fri Jun 07, 2024 3:28 pm
by maddog2020
looks like my failed pump is the FP200. It was installed in 7-2021 and has less than 2 hours of run time with 93 Octane pump gas. I had the pressure regulator set @ 55PSI.
Posted: Fri Jun 07, 2024 7:19 pm
In-tank pump is deleted with a strainer in place I assume?
Plans to autopsy the dead main pump?
Posted: Fri Jun 07, 2024 7:55 pm
by maddog2020
Car hasn't had an in tank pump in 20 years. I did replace the factory hose fitting on the tank with the Murphy version with a bigger hose barb, as well as larger ID and a larger screen. It also has a larger fitting on the Fuel pump side as well. Tank was removed from the car, and aggressively scrubbed internally numerous times and rinsed out repeatedly so I know it was as clean as a new one. This was done when the new pump was installed in 2021. I write a date on the fuel filter when I install them.
Posted: Sat Jun 08, 2024 12:04 pm
by maddog2020
new pump spec chart shows 12.2 amps when running @ 55PSI which is where I have it set. It also shows 388LPH (LIters per hour) at 55PSI, and could support 1130 HP at these numbers. Looks like it has plenty of buffer. These numbers are with gasoline, and I do plan on tuning with E85 at some point and I will need to switch injectors at that point as I only have 725cc injectors and there won't be enough margin for my taste. I do have a nice set of 1050cc Injector Dynamics injectors ready to go in. :)
