Posted: Mon Apr 22, 2024 8:08 pm
by Sazerac
Hi All
Re: Refurbishing D90 Wheels
Posted: Mon Apr 22, 2024 8:23 pm
by SeaCay
Posted: Mon Apr 22, 2024 8:37 pm
Posted: Tue Apr 23, 2024 5:05 am
by Sazerac
Good points.
Posted: Tue Apr 23, 2024 9:22 am
Posted: Mon Apr 29, 2024 12:47 pm
by Rick Carter
Posted: Wed May 01, 2024 10:01 am
by hessank
Posted: Wed May 01, 2024 12:24 pm
Cheese Grater Wheels.
No D90 DNA present.
Posted: Wed May 01, 2024 8:14 pm
by N_Jay
hessank wrote: Wed May 01, 2024 10:01 am Modern 'take' on D90s or just fugly?
"B"
Posted: Mon May 06, 2024 10:59 pm
by jschiller
Posted: Wed May 08, 2024 7:08 pm
by Sazerac
Posted: Thu May 09, 2024 10:16 am
by Gary Knox
Gary
Posted: Thu May 09, 2024 5:47 pm
by Sazerac
Posted: Tue May 14, 2024 4:31 pm
by Addlight
Gary
Matt
Posted: Sun Jun 09, 2024 10:54 am
by Sazerac
So, finally, in a casual exchange with an acquaintance in the CA area, he recommended these guys who prepared his D90s and repainted them (he did not choose the factory color):
https://www.ocwheelrepairs.com
Anybody heard of them? They would fit the bill in that they seem to be able to rebuild curb rash by welding and also they repaint alloy.
Posted: Wed Sep 17, 2025 6:11 pm
by Sazerac
This is a little bit of a thread revival... But I finally have some data. After looking and asking questions, I could never get any recommendations from anybody, so I tried to refurbish the following wheels (cast and painted D90s):
928.362.154.05 x 2
928.362.158.02 x 2
The shop I charged with the job was Fuchs Restoration: https://www.fuchsrestoration.com/
After writing a couple emails and never getting a response, on a whim, I sent a text message and actually got a response, "Yes, I refurbish D90s too. Just fill out the from and send them in." I checked the wheels were straight and shipped them off. The wheels were in ok shape prior to shipping, just quite a bit of curb rash and genereral scuffing. I told them to refinish the front and back and weld up the curb rash. and repaint. I told them explicitly to not paint over or weld over the D90 sensor holes.
The job wasn't cheap at about USD 650 per wheel, but I have no complaints. Also, these are NLA, so you if you have a set, take care of them.
Posted: Thu Sep 18, 2025 12:08 am
by Tony
I have a set, but they are chromed. :surrender: An even bigger issue to refinish!
Posted: Thu Sep 18, 2025 8:51 am
by N_Jay
Does anyone make reproduction D90 wheels?
They are among my favorite and think they would look well matched to my 914.
Not too modern, but not just another set of Fuchs.
Posted: Thu Sep 18, 2025 4:59 pm
by amdavid
Posted: Thu Sep 18, 2025 5:10 pm
17" D90s look to be about 4.5k a set.
I've been toying with the idea of having Augment make me a set of 17" Club Sport wheels in 9" and 10.5."
Posted: Thu Sep 18, 2025 8:25 pm
by N_Jay
worf wrote: Thu Sep 18, 2025 5:10 pm 17" D90s look to be about 4.5k a set.
Ouch!
That is quite speedy in 914 dollars.
Posted: Thu Sep 18, 2025 10:55 pm
I'm sure you can find a company that will reproduce them cheaper. In cast lead.
$1000-$1200 for a forged wheel is cheap.
Posted: Fri Sep 19, 2025 7:30 am
by N_Jay
worf wrote: Thu Sep 18, 2025 10:55 pm I'm sure you can find a company that will reproduce them cheaper. In cast lead.
I didn't say they weren't worth it, just not in my application.
Posted: Wed Sep 24, 2025 8:48 pm
by hernanca
Just visited the Augment site and they are offering free shipping to the US to offset the tariff charges. Don't know if their prices include the tariff, but I think they have increased the per wheel pricing.
Posted: Tue Sep 30, 2025 3:03 pm
by XR4Tim
N_Jay wrote: Thu Sep 18, 2025 8:25 pm
Ouch!
I've got a set from a low-mile 964 C2 that will cost you a lot less than that!
Posted: Wed Oct 01, 2025 8:49 pm
by N_Jay
Well, look what popped up on FB Market place
Design 90 Porsche rims removed from 1990 911 Targa (964). Good condition, minor scuffs
Rims: 16 inch, Front 6J x 16 (964.362.112.01), Rear 8J x 16 (964.362.116.01), Offset ET 52.3 front and rear.
Does $800 seem fair?
Posted: Thu Oct 02, 2025 1:39 am
by hernanca
They come with center caps, so that's a bonus.
Find out if they have the RDK holes/plugs. If so and you dont have (or dont want) that system, the holes will need to be plugged and wheels rebalanced.
1990-1991 928 came with 7.5et65 and 9et52.3 D90s, all with the RDK holes. (Info courtesy of 928 Specialists site (928gt.com)).
Posted: Thu Oct 02, 2025 6:00 am
hernanca wrote: Thu Oct 02, 2025 1:39 am ... If so and you dont have (or dont want) that system, the holes will need to be plugged and wheels rebalanced.
This assumes that the holes are empty. They probably aren't since it requires two Por$sche $pecial tool$ to remove the RDK devices. (They aren't called, properly, 'senders' IMO.)
Provided that there's no leak between the RDK bits and the wheel barrel you don't *have* to remove them provided there's sufficient clearance for the caliper and other bits that protrude into the barrel.
Posted: Thu Oct 02, 2025 11:27 am
by N_Jay
hernanca wrote: Thu Oct 02, 2025 1:39 am They come with center caps, so that's a bonus.
Did the 964 version use those sensors?
Posted: Thu Oct 02, 2025 11:29 am
by N_Jay
worf wrote: Thu Oct 02, 2025 6:00 am
Well, they will be going on a street 914 running 1980's 911/930 brakes so I am guessing space in the barrel should not be a concern.
Posted: Thu Oct 02, 2025 9:00 pm
by hernanca
I (obviously) did not know this. The folklore I recall was that they were problematic. What have you seen? If they retain those not-worthy-to-be-called-sensors plugs , do they tend to be air tight? Is a $pecial Por$che Tool($) required to INSTALL them if missing?
N_Jay wrote: Thu Oct 02, 2025 11:27 am Did the 964 version use those sensors?
No idea! Wiki says 964 was 89-93, so I would guess "maybe-yes"? :biggrin: Maybe assume yes & ask the seller to show pictures of the holes so you can see if plugged or not.
Posted: Thu Oct 02, 2025 9:14 pm
hernanca wrote: Thu Oct 02, 2025 9:00 pm I (obviously) did not know this. The folklore I recall was that they were problematic. What have you seen? If they retain those not-worthy-to-be-called-sensors plugs , do they tend to be air tight? Is a $pecial Por$che Tool($) required to INSTALL them if missing?
The 'sensors' in the wheels are sealed with an o-ring to the wheel barrel. I have never - personally - found one, installed by the factory, in an undamaged wheel leaking. So, this is a case where, if it ain't broken don't fix it unless you have to.
And yes, the two-part Special Tools (and two people) are required to R&R them.
The main 'problem' with RDK was that it was not user adjustable. The warning trigger pressure was fixed by the 'not-a-sender' in the wheels. The secondary 'main' problem was folks trusting that their $1.99 gas-station pencil pressure gauge was more accurate.
IIRC, the WSM, or the '89 or '90 928 Service Tech Info books have a good description of the theory of RDK operation. I will not attempt to describe how it works from memory. But, it is *nothing* like modern TPMS systems that have batteries and transmitters in the in-wheel senders.
AFAIK, RDK was only, ever, on the 928. (Perhaps also the road-going 959.)
Posted: Thu Oct 02, 2025 9:33 pm
by N_Jay
From a few Googles (not 100%trusting what I found) although available, a 964 would have to have been very highly optioned to have them.
Searching the wheel part numbers, they are not mentioned, nor do they show in any pictures I have found.
I will know when I look at them, but probably doesn't change my stance.
If they look good and strait, with fairy new tires, a good enough deal.
Posted: Fri Oct 03, 2025 8:15 pm
by N_Jay
Well, the 914 has new wheels.
These did not have the "not a sensor" bores.
Wheels are really nice for "driver" quality.
See the latest purchase thread for pictures.
viewtopic.php?t=86&start=2900#p321225
Offered up $750 and they said OK. Venmo stole their 3% because I refuse to link my bank account.
Still under $800 and the tires are almost new.
Thanks everyone for the insights.
Posted: Sat Oct 04, 2025 12:49 am
by hernanca
N_Jay wrote: Fri Oct 03, 2025 8:15 pm Well, the 914 has new wheels.
Good to know those don't have the bores.
We need to see them ON the 914 however! I have always loved how the 914's looked, especially at the track. They just always seemed to have the right stance for the track. And there is at least one 914 with a 928 V8 in it (and Pascha interior!) by a guy named Rick:
