Stock Fuel Injectors - Where to go from here?
Posted: Sun Jan 21, 2024 12:57 pm
by Sazerac
Hello All
So, let's say that one has the feeling that his fuel injectors are contributing to a slightly rough idle on a 91 GT with ca. 95.000 miles on the clock and otherwise in very good shape.
Are most people still rebuilding the old ones still or is the preferred choice now actually updating to newer injectors? If updating, what are people doing to the accommodate new injectors?
Any feedback would be interesting.
Cheers, John
Re: Stock Fuel Injectors - Where to go from here?
Posted: Mon Jan 22, 2024 6:57 am
by linderpat
rebuild the old. There are some good vendors out there that can make them function like new. I used RC Fuel Injection out of Torrance CA for mine, which were original injectors and in desparate need of refurbish when I got my current 85.
Posted: Mon Jan 22, 2024 7:07 am
by Geza-aka-Zombo
I had my OE injectors (~130K miles) cleaned. Note: RC sends them back painted and with new O-rings.
Posted: Tue Jan 23, 2024 9:21 am
by Mrmerlin
I would run a few bottles of Techron and 6 OZ of MMO through the fuel system before you take the injectors out.
NOTE do short drives so the chemicals have time to work
Posted: Tue Jan 30, 2024 6:28 pm
by Sazerac
Ok, well, thanks for the answers.
I did have the injectors cleaned not too long ago. But let me keep thinking.
It's a strange guess but my fuel pump is making lots of noise, so before I do anything with the injectors, I am going to change that first.
Posted: Tue Jan 30, 2024 8:34 pm
by Zirconocene
I went down an injector rabbit hole recently and came across these, for surprisingly little money:
https://cars245.com/en/item/bosch-0280158107-injector/
The flow with heptane works out to about 20 lb/hr, or roughly 3.14 microhogsheads/attosecond, so they're at least in the right ballpark, and have the right (EV1) connector. All that said, I have not been able to confirm what other parameters I should be looking at (though the impedance looks OK), so take this all for what it's worth.
Cheers
