analogue clock wiring question
Posted: Sat Dec 30, 2023 11:09 am
by h2pmr
removed this original analogue clock from the 90 S4 + its original wiring loom and connector and it has the usual 12v, earth and 12v for the light + a wire in the connector- the black one in the pictures- that is "not used " according to the pictures i have seen on the www.
anybody know what why the clock would need this wire ?
flux capacitor ?
Re: analogue clock wiring question
Posted: Sat Dec 30, 2023 12:55 pm
Red is 30 Bus 12v
Black is 15 Bus 12v
Black/Blue is …. dimmer?
Have you looked at the wiring diagrams?
Posted: Sat Dec 30, 2023 2:37 pm
by h2pmr
was being lazy
had it hooked up to a battery with just the red and brown wires and it kept perfect time for the last 6 hours which is a good start, new bulb and that now works
will check the wiring diagram, thanks Dave
Posted: Sat Dec 30, 2023 2:40 pm
h2pmr wrote: ↑Sat Dec 30, 2023 2:37 pm
was being lazy
lol. me too.
Posted: Mon Jan 01, 2024 5:22 am
by h2pmr
i just hooked it up to a battery, brown on earth then tried all other combinations of 12v on the other 3 wires and the black one alters nothing, as it comes from the light switch i thought it might light the bulb to possibly keep it illuminated as a belt and braces approach but light only comes on with the blue/black wire at 12v
BUT
12V on blue/black wire = 0.5V on black wire
0V on blue/black = 0V on black wire
its sending a 0.5V signal OUT on the black wire
or there is a fault on the black wire circuit inside the clock
