how does the oil level sensor work?
Posted: Sun Aug 27, 2023 5:16 am
by h2pmr
i might be thick but how does the float make any form of contact if there is a rubber ring at both ends of it slide?
how does it open or close the circuit ?
wire pictured should go up the middle of the float shaft.
Re: how does the oil level sensor work?
Posted: Sun Aug 27, 2023 6:49 am
by smiffypr
Reed switch inside the shaft and magnet in the float.
Posted: Sun Aug 27, 2023 7:47 am
by h2pmr
ahh i see, that's what's missing from my wire up the shaft, Thanks Smiffy
Posted: Wed Aug 30, 2023 2:37 pm
by h2pmr
thought i would see if i could put a new reed switch in.
not a good idea using a finger as a make shift solder sucker though... :kickbutt:
Posted: Fri Sep 01, 2023 3:44 pm
by h2pmr
got the new reed switch soldered to the top of the housing, but then found the reed part to long so the magnet float is opening it in any position.
need to find a very short reed switch.
a future project.
