Jeep Electric Wrangler.
Posted: Thu Sep 03, 2020 1:37 pm
At first I thought, cool concept.
"The electrified Wrangler is just as capable in the dirt and on the rocks as its gasoline-only counterpart. Every 4xe boasts a pair of solid Dana 44 axles, a two-speed transfer case that enables full-time four-wheel drive, 10.8 inches of ground clearance, and the ability to ford up to 30 inches of water. If your first impulse was to think water and electric vehicles go together like smoking while pumping gas, relax. Jeep says all the 4xe's high-voltage components are sealed and waterproof. Whew.But then I read:
Not only is the 4xe just as well equipped to explore parts unknown as the regular Wrangler, it's actually more powerful. With one electric motor mounted at the front of the 4xe's turbocharged 2.0-liter inline-four and another mounted at the front of its eight-speed automatic transmission, the hybrid Wrangler generates a combined 375 horsepower and 470 lb-ft of torque. Those figures exceed all of the lineup's nonhybrid engines, including the diesel 3.0-liter V-6 that develops 442 lb-ft. Even if Jeep actually builds the 450-hp V-8–powered Rubicon concept, the plug-in hybrid will still have an advantage of 20 lb-ft over the 6.4-liter Hemi."
Feeding the Wrangler 4xe's electric motors is a 17.0-kWh lithium-ion-nickel-manganese-cobalt battery pack,and thought....."Recharged by coal and natural gas."
