Brittle ABS Connectors
Posted: Wed Jun 28, 2023 8:35 pm
by gregn928
While beginning the process of replacing my front right ABS harness, I discovered that the connectors in the engine compartment had become so brittle with age and heat that they are disintegrating with even the slightest movement:
Does someone have some wise advice on how I should proceed?
I'm also noticing that there is not much clearance between where the ABS harness passes through the fender wall and the two A/C lines that run right by that same location. It seems like it will be a real challenge to push the new connector through from the outside:
Replacing the font left ABS harness was so easy that it was almost fun. This front right one is the opposite of that!
Re: Brittle ABS Connectors
Posted: Wed Jun 28, 2023 9:32 pm
by maddog2020
a guy on facebook sells 3d printed inserts that secures 6 pin Deutch connectors. It's a pretty good solution.
Posted: Wed Jun 28, 2023 9:42 pm
by maddog2020
I got a couple of sets and they fit the connectors I got here
https://www.amazon.com/gp/product/B09V7 ... =UTF8&th=1
Posted: Wed Jun 28, 2023 10:52 pm
by gregn928
Thanks for the info, Maddog, but that Facebook link didn't come through. You can probably see above that it says "This Facebook post is no longer available. It may have been removed or the privacy settings of the post may have changed."
Posted: Thu Jun 29, 2023 11:02 am
by SeanR
I cut all the bad stuff out and replace them with these.
I’ve also used the 4 pin ones but they are not as easy to use. Sorry I didn’t reply to your email quicker but seeing this post reminded me.
Posted: Thu Jun 29, 2023 11:08 am
Greg, it sounds like you’ve replaced the left side with a new harness already and the only challenge you face is how to replace the right side harness?
Yes, the right side sucks, but it can be done (without pulling the motor too!)
If you get stuck pulling the replacement into the engine bay then unfasten the 2 p-clamps that keep the A/C lines secured to the engine compartment. Then you’ll be able to wiggle them the few MMs need to get the connector through.
Posted: Thu Jun 29, 2023 5:47 pm
by gregn928
worf wrote:Greg, it sounds like you’ve replaced the left side with a new harness already and the only challenge you face is how to replace the right side harness?
David, Correct. I have a new ABS harness for the right front, but now I can't use it because the little connectors on the engine harness side are too brittle and falling apart. It sounds like the correct path forward is to snip the engine compartment connector off my new $170 ABS harness and use the Deutsch connectors instead. In hindsight, I think I should have just stayed with my old harness and replaced the disintegrated rubber sheathing in the wheel-well by wrapping with rubber sealing tape. But, looking at the bright side, if I lop off the big white connector from the new harness, it should be trivial to feed it though the fender wall opening and then put the Deutsch connector on afterward!
SeanR wrote:I cut all the bad stuff out and replace them with these. [2-pin connectors] I’ve also used the 4 pin ones but they are not as easy to use. Sorry I didn’t reply to your email quicker but seeing this post reminded me.
No problem, Sean. I know you're a busy man.
Now I'm confused as to whether I should use 2-pin, 4-pin or 6-pin Deutsch connectors in the engine bay. The harness has five wires, which I assume are:
2 ABS speed sensor
2 Brake pad warning
1 Ground
On the wheel side of the harness it makes sense to use the 2-pin connectors. But in the engine bay wouldn't it be better to use 4-pin or 6-pin? If the 2-pin are easier to use Sean, would you please explain how?
Hmm. I don't actually use my brake pad sensors, so now I'm tempted to just short that connection on the engine harness and utilize only a single 2-pin connector (for the wheel speed sensor). Would that be too sloppy? I don't normally cut corners. So many options to consider.
Posted: Fri Jun 30, 2023 10:45 am
gregn928 wrote: ↑Thu Jun 29, 2023 5:47 pm
Yup. This (dying ABS Harness connectors) is something we will all face real soon now.
I have an unused Deutsch connector kit on hand for my first client with dead ABS harness connectors.
Well... there's also the issue of the weird rubber grommets on the wheel well harness that are retained by the U-shaped plastic retainers.
Those grommets are available after market but they are pricy for a full-car set (~350). Jeannie has a couple of sets in stock if you want them.
True.
It seems unlikely that 'originality' will ever be really useful, since I highly doubt you'll ever sell your 928.
And in any case, when I am forced to resort to 'creative methods' many barriers to originality fall.
So, yeah, I'd probably just do a two pin for the ABS too on either my '89 or '91. For the GTS, I'd probably have to bite the bullet and buy a new ABS body harness.
Posted: Tue Jul 11, 2023 10:51 pm
by maddog2020
Ironically Greg and I both were working on this tonight. I went with the 6 pin Duetch connectors like Sean posted and I added the barrel snap in's from the guy on ebay. Both sides done...
Posted: Wed Jul 12, 2023 1:40 am
maddog2020 wrote: ↑Tue Jul 11, 2023 10:51 pm
Nice. Can you post the ebay link?
Posted: Wed Jul 12, 2023 8:35 am
by maddog2020
no marketplace add, just contact the guy in the 3rd post from the top.
Posted: Wed Jul 12, 2023 10:08 am
maddog2020 wrote: ↑Wed Jul 12, 2023 8:35 am
There is no “guy” in the 3rd post. There’s a 404 facebook link. Your last post said ebay.
Posted: Wed Jul 12, 2023 1:37 pm
by maddog2020
my bad. facebook not ebay. Guy named Victor Belanich. He posts on the 928 Docs page. If you do a search you can find his post about these.
Posted: Wed Jul 12, 2023 2:27 pm
by gregn928
I just couldn't convince myself to chop the big, white cylinder off my new $170 ABS harness. So, I ended up doing it the hard way. I decided to replace the disintegrated 2-pin connectors on my engine harness by buying a couple of eBay items. I found a 928 brake pad sensor for $9 and a Boxster ABS sensor for $20. I harvested the 2-pin connectors from the eBay parts to make pigtails and spliced them in to the engine harness. Here is the the final result:
Posted: Wed Jul 12, 2023 3:17 pm
by maddog2020
I didn't have to chop anything , the 2 pin ones from the main harness disintegrated in my hands and the big barrel connectors I squeezed with channel locks and heard them cracking like walnuts or the titan. then cut off the soldered pins. technically the ABS double pin could be salvaged from old abs sensors and the brake pad warning connector could be salvaged from old brake pad sensors. at this point I'm not throwing away anything that comes off the 928.
Posted: Thu Jul 13, 2023 7:13 am
by fpena944
I'm not sure if this company would have this connector or not but on my Cayenne I had the same problem with the thermostat connection and didn't want to buy an entire wiring harness.
So I went here and described what I needed to the rep via online chat and they found the right part for me:
https://findpigtails.com/
It was expensive but exactly what was needed and got rid of my issue (which reminds me I need to update this thread:
Cayenne P0599 code - "Thermostat Heater Control Circuit High"?!?) and secured the connection.
Try them out and let us know if they happen to have it. It might be worth a shot.
Posted: Tue Jul 18, 2023 9:03 am
by The Fat Man
For what it is worth, I tracked down the gentleman on FB 928 Docs that 3D printed the barrel adapters for using Duetsch connectors.
Here is his ebay listing:
https://www.ebay.com/itm/305021891511
I bought 4 sets for future use on the Red Witch.
Posted: Sun Jul 23, 2023 3:26 pm
gregn928 wrote: ↑Wed Jul 12, 2023 2:27 pm
Greg, I'm going to do the same thing. Can you post the ebay link to the Boxster ABS sensors? Thanks.
Posted: Mon Jul 24, 2023 2:08 pm
worf wrote: ↑Sun Jul 23, 2023 3:26 pm
Or, just the part number.
Thanks.
Posted: Mon Jul 24, 2023 3:25 pm
by Zirconocene
@worf : You'll get the right PN, I'm sure, but just for S&Gs I took a look at PET and, lo and behold, there's a familiar PN lurking in that document: 928 612 566 00.
You told me at Camp 928 that 928 PNs show up on the 959, as well, which I think is super cool, but I've never been able to download that PET PDF. I did get a chance to ogle a 959 up close, however, and the airbox is eerily reminiscent of what's in the 928, so there's at least an influence in that particular PN.
/Random tangent
