Teutonic 928 hotrodding thread
Posted: Tue Jun 06, 2023 10:23 am
by Strosek Ultra
Rob Edwards on another 928 forum.
Åke
Re: Teutonic 928 hotrodding thread
Posted: Tue Jun 06, 2023 9:41 pm
by The Fat Man
I like his avatar... :biggrin:
Posted: Sun Jun 11, 2023 10:21 am
by Strosek Ultra
Mr. Brown did not like the posting of these pictures.
See Teutonic 928 hot rodding thread post # 212.
Åke
Posted: Mon Jun 12, 2023 12:13 am
by maddog2020
you really need to see post 249 as well. another engine toasted.
Posted: Mon Jun 12, 2023 4:57 pm
by hessank
What does the underside of this intake looks like, or company secret?
An inquiring mind wants to know
Posted: Mon Jun 12, 2023 5:01 pm
by Don Smith
I don’t know, but the top looks like Chevrolet.
Posted: Mon Jun 12, 2023 5:20 pm
by fpena944
Strosek Ultra wrote: Sun Jun 11, 2023 10:21 am Mr. Brown did not like the posting of these pictures.
Åke
So what is that in there?
Looks like melted peanut brittle.
Posted: Sat Jun 17, 2023 3:34 am
by Strosek Ultra
hessank wrote: Mon Jun 12, 2023 4:57 pm What does the underside of this intake looks like, or company secret?
As a Copycat Mr. Brown has designed this intake manifold to resemble ditto V8 manifolds found on BMW V8, Cayenne V8 and other engines from the 1990s.
From a power point of view, it is placed between the original 928 manifold and ITBs. Attached picture shows the underside of one BMW manifold.
Åke
Posted: Sat Jun 17, 2023 12:09 pm
by hessank
Thanks Åke.
I saw that it resembled the Cayenne V8 that sells for <$200
Posted: Sat Jun 17, 2023 9:29 pm
by maddog2020
https://tapped-performance.myshopify.co ... fold-black
4.8" for the Hemi big block bore spacing is really close the the 4.803" (122mm) bore spacing the 928...
Posted: Sun Jun 18, 2023 1:11 am
by Daniel5691
Hey is that Seth's old avatar ??
Posted: Sun Jun 18, 2023 2:38 am
by Strosek Ultra
maddog2020 wrote: Sat Jun 17, 2023 9:29 pm https://tapped-performance.myshopify.co ... fold-black
4.8" bore spacing on hemi big block that matches our bore spacing...
122mm bore spacing. Remember the 928 is a german car and everything is metric.
Åke
Posted: Sun Jun 18, 2023 4:23 pm
by maddog2020
Strosek Ultra wrote: Sun Jun 18, 2023 2:38 am
Åke
3 thousands can be ported to match really easily. if the distance between the ports from one bank to the other is close this could be and easy fit especially considering how cheap it is.
Posted: Sun Jul 02, 2023 6:31 am
by Strosek Ultra
What I meant is that the 928 is built according to the metric system, therefore one should avoid translating measures and dimensions to the imperial system.
Åke
Posted: Sun Jul 02, 2023 11:00 am
Strosek Ultra wrote: Sun Jul 02, 2023 6:31 am What I meant is that the 928 is built according to the metric system, therefore one should avoid translating measures and dimensions to the imperial system.
I agree. But, good luck with that.
I have, effectively zero SAE tools and work exclusively in metric. It confuses the hell out of people here, even dealer techs.
Posted: Sun Jul 02, 2023 11:24 am
by maddog2020
I work exclusively with metric but some of the parts on my stroker motor, (rod bolts) are SAE. All of my fuel lines and oil lines are AN-6 or AN-10. When comparing the 928 engine to domestic engines you have to be able to convert metric to sae. The point that I was trying to make is that there are a good number of off the shelf intakes for the 1st gen HEMI engines to find an intake cheaply and make adapters to bolt onto the 928. Every machine shop in the US is based on SAE decimal. no fractions no metric. If you want something machined you start there. The intake above is $600 USD. Have some adapters made and save 5K (again USD) & get the latest intake design and its affordable. Most of us on this forum are in the US, so some of us will use both metric and SAE. Metric or SAE are both units of measurement. The dimensions don't change. US cars now use a mix of both. I'm glad I don't work on those. :deadhorse:
