Best intake refresh instructions?
Posted: Fri May 12, 2023 9:42 am
by JBT3
@worf Is this your latest and greatest? I came across an old post on that other site that sounded like you were updating.
http://www.928intl.com/repair/intake1b.pdf. Thanks.
Thanks all.
JT
1990 GT
Re: Best intake refresh instructions?
Posted: Fri May 12, 2023 9:53 am
‘compete?’
Posted: Fri May 12, 2023 10:52 am
by linderpat
Posted: Fri May 12, 2023 12:58 pm
by JBT3
Thanks Dave and Ed. I’ll read Dave’s and Dwayne’s write ups again and hope to jump on this soon.
Posted: Fri May 12, 2023 5:40 pm
by Crumpler
This is S3 centric but points to Scott for a great write up. Interesting guy of many skills.
https://scott-yoo.com/porsche/1986-5-92 ... procedure/
Posted: Sat May 13, 2023 8:51 pm
by MFranke
Posted: Mon May 15, 2023 7:14 am
by Geza-aka-Zombo
Posted: Tue May 16, 2023 3:53 pm
by JBT3
Posted: Wed May 31, 2023 9:28 am
by JBT3
So intake is off and I’m working on removing the cam covers. Found this lovely sight when I went to remove the right side engine hook.
Going to try vice grips and a stubby screw driver to get it out and replace with a proper m8 hex head bolt.
Posted: Wed May 31, 2023 9:29 am
by JBT3
Also any tips on reaching the driver side hook bolts? Looks way to tight from below.
Posted: Wed May 31, 2023 11:35 am
by WyattsRide
Posted: Wed May 31, 2023 1:54 pm
by JBT3
Thanks Rick!
I must have misread the parts pdf. I saw quantity of 2 and thought someone had done a hack job on a bolt. I guess the two were for the left and fright engine hook. That’s a big time saver.
Posted: Wed May 31, 2023 5:09 pm
It’s a blind, by feel job.
Posted: Fri Jun 02, 2023 11:57 am
by Charlie
