How to calibrate voltmeter analogue dash
Posted: Fri Apr 14, 2023 1:34 pm
while i have the dash apart i thought i would also check the calibration of the voltmeter.
an ideal "while you are in there already" job.
voltmeter on dash
on the rear of the voltmeter 12v feed is the red wire and the earth is the brown wire
metal disc on the side of the voltmeter is the adjustment potentiometer need a tiny screwdriver in the center slot to move it
if you don't have a power probe or voltage generator, here is an easy way.
assume the battery in the pictures below is on your daily driver car, not the 928 you are working on.
connect the brown wire from the back of the voltmeter to the battery earth and also the earth lead from a digital multi meter.
then connect the red wire from the voltmeter to the battery 12v terminal along with the 12v lead from the digital multi meter
and depending on how good your battery is you will get a reading as below
so the voltmeter SHOULD also now read the same as the digital multi meter, if not turn the little potentiometer, does not need turning very much to alter it
then start your car and again the voltmeter should read the same as the digital multi meter, approx 14v
hope this helps somebody
voltmeter on dash
