Coolant leak, odd behavior
Posted: Thu Aug 27, 2020 3:09 pm
Well, it's only odd to me cause I don't understand :roll: . 87S4, about six years ago and 40K miles I did the WP (Laso, plastic impeller), I also freshened up everything on the car since then. New radiator, coolant tank, hoses, etc on and on. Always ran fine on the temp side, fans work correctly. Zero leaks.
So I moved from Cali a few years ago to Colorado. Last winter was very cold here (single digits often). I kept the car in the garage for the most part but did drive it on clear dry days. Started noticing after letting it sit for a few days I would lose a a cup or so of coolant, seemed to be below the WP or in that area (pans on, never pulled them to look closer). Pretty bummed, thinking WP bad, but then spring arrived and I drove it some more and suddenly no more leaks. I even drove to South Dakota last month for Rendezvous and I have not lost a drip of coolant since winter.
Sorry for the long-winded story, but can the extreme cold cause a leak to surface in the WP? I have pulled the front pan off a few months ago and see no evidence of past leak. Shrinkage factor on the impeller bearing?
