Fuel pump electrical wiring dust caps
Posted: Wed Oct 12, 2022 7:57 am
by Don Smith
Good morning guys and gals.
I just did a fuel pump replacement,filter and cross over pipe, and it all went well. But....there is always a but. My electric wires and rubber covers were both hard. I have been looking for a source of these rubber boots, but not found one locally, yet. Any good source out there, besides the stealer.
Don
Re: Fuel pump electrical wiring dust caps
Posted: Wed Oct 12, 2022 9:49 am
Posted: Wed Oct 12, 2022 10:26 am
by Bertrand Daoust
Is the boot that Roger sells for the oil level sensor would fit?
It looks quite similar to what I have on my fuel pump.
Posted: Wed Oct 12, 2022 8:48 pm
by Don Smith
Thank you both. I will call Roger tomorrow morning.
Posted: Thu Oct 13, 2022 8:45 am
by Don Smith
And as a follow up, Roger has them for $5.25 each. Ordered along with some graphite bearings for my new Hans shift kit.
My car is going to be a perfect driver, after this, but unfortunately, it goes away till spring, and I will have to wait to do these small changes.
Oh well, third world problems!
Posted: Thu Oct 13, 2022 10:51 am
Don Smith wrote: ↑Thu Oct 13, 2022 8:45 am
Which? The correct boots or the boots for the level or pressure senders?
Why? Is something missing from
@hans14914’s kit?
Posted: Thu Oct 13, 2022 12:58 pm
by hans14914
Dave - he is referring to the aftermarket "911" poly-graphite bushings to rebuild the rear coupler. I generally advise people to replace the coupler bushing with a round-hole (911) bushing as opposed to the silly slot bushings used in the 928 coupler. Even a brand new one has over 1mm of random travel in the slot.
Posted: Thu Oct 13, 2022 4:09 pm
hans14914 wrote: ↑Thu Oct 13, 2022 12:58 pm
Ah.
I just cut on of the old shift handle bushings in half and stick the halves in the oval.
Posted: Fri Oct 14, 2022 9:09 am
by Don Smith
Yes, Dave, the rubber boots for the fuel pump were $5.25 each, and I did as Hans suggested, for the polygraph its bushings. I am only going in there once!
Thanks for your help.
Posted: Sat Oct 15, 2022 7:54 pm
by hilton
These may fit?
928 612 497 00
Protection cap for the 2-wire oil pressure sender
I used them for the AC pressure sender years ago (returning my '89 to stock as it had a combined sensor from a PO). Not quite as big a diameter as the fuel pump's stubs, but close.
pic on Theo's site:
https://jenniskens.livedsl.nl/Technical ... Tip673.htm
