W-Washer pump grommet part# 431 955 465B
Posted: Wed Aug 26, 2020 1:28 pm
by hessank
Any alternatives to this?
Otherwise I have to wait for 3 weeks from Germany. Shipping from the US via USPS is crazy.
Still waiting for a used headlight switch for 35 days now.
Re: W-Washer pump grommet part# 431 955 465B
Posted: Wed Aug 26, 2020 3:00 pm
hessank wrote: Wed Aug 26, 2020 1:28 pm Any alternatives to this?
I've got a new one of those in (should be in) a box that arrived today after, yes, a multi-week wait. First time in 20 years that I've ever needed one.
It appears that that grommet both seals and retains the washer pump. It would appear that while yours is cracked the sealing portion may still function and the retention functionality shouldn't be compromised.
Do you know that it leaks? Or do you just want to have one that isn't broken?
Posted: Wed Aug 26, 2020 4:08 pm
by hessank
Yes, it drips.
I've gone ahead and ordered one. 3 week wait.
I've also found my break in the brake pad circuit. Luckily at the same passenger wheel that was out.
Maybe I should go buy a lottery. Such luck does't happen that often with this car; a true labor of love.
Posted: Wed Aug 26, 2020 5:32 pm
hessank wrote: Wed Aug 26, 2020 4:08 pm Yes, it drips.
You could always experiment with an o-ring between the grommet and tank if the broken grommet holds the pump. Removing the tank is only fun if the entire front suspension is on the ground in pieces. I hate doing stuff twice. So if the correct part is available I'll almost always go that route.
Luck happens.
