Page 12 of 17
Re: The 928 Photo Thread
Posted: Fri Jun 17, 2022 3:43 pm
by h2pmr
its NLA from Porsche.
Posted: Sun Jun 19, 2022 3:06 am
by Strosek Ultra
Think I can show this without being called a copy cat by someone.
Åke
Posted: Sun Jun 19, 2022 5:13 am
by h2pmr
Åke
plenty of knowledge without the ego's = a far more easy going forum in my opinion
Posted: Sun Jun 19, 2022 1:31 pm
by XR4Tim
Posted: Sat Jul 09, 2022 6:57 am
by h2pmr
Posted: Sat Jul 09, 2022 10:44 am
Strosek Ultra wrote: ↑Sun Jun 19, 2022 3:06 am
Edit: Forgot picture…
Posted: Sun Jul 10, 2022 10:02 am
by Crumpler
More speed, more brake.
GTS calipers from Kevin.
Posted: Wed Jul 13, 2022 4:48 pm
by Bertrand Daoust
Once a year wheel well cleaning today!
Posted: Wed Jul 13, 2022 8:36 pm
by Crumpler
Posted: Thu Jul 14, 2022 2:56 pm
by h2pmr
Crumpler wrote:
water cooled intercooler?
Posted: Thu Jul 14, 2022 9:59 pm
by Crumpler
Bingo Phil :)
Posted: Thu Jul 14, 2022 10:56 pm
by XR4Tim
Posted: Fri Jul 15, 2022 11:21 am
XR4Tim wrote: ↑Thu Jul 14, 2022 10:56 pm
... pic ...
NOS right-side parcel shelf?
Posted: Fri Jul 15, 2022 9:29 pm
by XR4Tim
worf wrote: ↑Fri Jul 15, 2022 11:21 am
... pic ...
Yes!
Posted: Wed Jul 27, 2022 6:35 am
by Bertrand Daoust
From this year PVGP,
Posted: Mon Aug 01, 2022 11:20 pm
Quiz:
Posted: Tue Aug 02, 2022 3:19 pm
by h2pmr
no need to get the apprentice to try and make some out of a cut off bolt head, i have a few spare if you need any
other than that i am out of ideas
Posted: Tue Aug 02, 2022 5:09 pm
by Rdon
“Flappy valve” stop
Posted: Tue Aug 02, 2022 5:20 pm
by Rdon
Posted: Thu Aug 04, 2022 7:54 pm
Rdon wrote: ↑Tue Aug 02, 2022 5:09 pm
“Flappy valve” stop
Correct!
Posted: Fri Aug 05, 2022 7:44 am
by Rdon
worf wrote: ↑Thu Aug 04, 2022 7:54 pm
Posted: Sat Aug 27, 2022 4:28 am
by Strosek Ultra
Åke
Posted: Sat Aug 27, 2022 7:35 am
by h2pmr
Åke[/quote
Posted: Sun Aug 28, 2022 3:41 am
by Strosek Ultra
Posted: Sun Aug 28, 2022 4:42 am
by h2pmr
Posted: Sun Aug 28, 2022 6:51 am
by Strosek Ultra
h2pmr wrote: ↑Sun Aug 28, 2022 4:42 am
Åke
Posted: Sun Aug 28, 2022 12:07 pm
by h2pmr
Strosek Ultra wrote:h2pmr wrote: ↑Sun Aug 28, 2022 4:42 am
Åke
Posted: Sat Sep 03, 2022 3:28 am
by Strosek Ultra
Strosek cars.
Åke
Posted: Sat Sep 03, 2022 5:53 am
by Strosek Ultra
Finally finished painting the three white garage doors.
Åke
Posted: Sat Sep 03, 2022 9:54 am
by SeanR
Posted: Sat Sep 03, 2022 3:03 pm
by h2pmr
Posted: Sun Sep 04, 2022 3:25 am
by Strosek Ultra
FULL DESIGNATION: AC 35x55x20
( d ) INNER DIAMETER: 35 mm
( D ) OUTER DIAMETER: 55 mm
( B ) WIDTH: 20 mm
Åke
Posted: Sun Sep 04, 2022 4:07 am
by h2pmr
Strosek Ultra wrote:image.png
( B ) WIDTH: 20 mm
Åke
perfect, many thanks Ake
Posted: Mon Sep 05, 2022 5:27 am
by Strosek Ultra
Strosek cars are out and about.
The old man with the walker is not a Porsche owner.
Åke
Posted: Sat Sep 10, 2022 10:45 am
by h2pmr
( B ) WIDTH: 20 mm
Åke
Posted: Sat Sep 10, 2022 1:21 pm
by h2pmr
Posted: Sat Sep 10, 2022 6:04 pm
by Bertrand Daoust
A 928 meet today in Montréal.
Thanks Andy!
And two very special guests!
Posted: Sat Sep 10, 2022 9:36 pm
by Bertrand Daoust
Posted: Sun Sep 11, 2022 2:55 am
by Strosek Ultra
h2pmr wrote: ↑Sat Sep 10, 2022 1:21 pm
Can be found on Ebay or here
https://www.bearingwholesalelots.com/40 ... on-com.htm
Åke
Posted: Sun Sep 11, 2022 11:11 am
by h2pmr
Strosek Ultra wrote:h2pmr wrote: ↑Sat Sep 10, 2022 1:21 pm
Åke
Posted: Mon Sep 12, 2022 2:06 pm
by SeanR
Posted: Sat Sep 17, 2022 6:54 am
by h2pmr
Åke
Posted: Sun Sep 18, 2022 2:58 pm
by h2pmr
lack of use in the UK
Posted: Sun Sep 18, 2022 3:00 pm
by h2pmr
N/A to auto owners
Posted: Sun Sep 18, 2022 3:13 pm
by h2pmr
Posted: Mon Sep 19, 2022 12:35 am
Posted: Tue Sep 20, 2022 6:04 pm
by XR4Tim
Posted: Mon Sep 26, 2022 1:20 pm
by Strosek Ultra
Porsche meet at Tjällmo, Sweden.
Åke
Posted: Mon Sep 26, 2022 1:27 pm
928 Frenzy. Last Saturday.
Posted: Mon Sep 26, 2022 1:28 pm
by SeanR
