If belts don't break, why do we replace them?
Posted: Thu Jul 07, 2022 7:57 pm
So talking to people at SITM about belt changes and the consensus was that no one has seen a 928 belt fail.
What apparently fails is the items touching the belt. Idler pulleys, water pump, tensioner pulley, gears. All resulting in the item jamming, smoking the belt, then causing a failure either immediately or upon a restart once the molten belt is welded to the item in question.
So why replace the belt? Instead just pull and replace all the pulleys+pump and be done with it. One can set the car to 45 degree time, mark the belt at the engine and each gear, then put it back on.
- No more underneath to remove the starter and lock the flywheel.
No more 300 ft pounds of torque on the crankshaft pulley
No more futzing with the resonator
Etc.
