Cayenne Turbo oil leak
Posted: Fri Jun 10, 2022 9:20 am
by fpena944
Changed the oil in our 2011 Cayenne Turbo about two weeks ago. Took a 1200 mile road trip since then so the fact that I just found a small puddle of oil on our garage floor is quite concerning to me.
I don't have the car in front of me but when my wife brings it home, what are some of the areas I should try to focus on for source of leaks?
Re: Cayenne Turbo oil leak
Posted: Fri Jun 10, 2022 11:17 am
by XR4Tim
Drain plug and filter housing are both pretty common spots. Also, if you've got PDCC, check the lines by the front sway bar.
Posted: Fri Jun 10, 2022 5:23 pm
by lupo.sk
Check intercoolers, oil pools in driver’s side IC lower pipe
Posted: Fri Jun 10, 2022 8:34 pm
by fpena944
XR4Tim wrote: ↑Fri Jun 10, 2022 11:17 am
lupo.sk wrote: ↑Fri Jun 10, 2022 5:23 pm
Thank you both. I checked the oil level and it's still the same level it was after I changed the oil. So hoping it's maybe just something that accumulated over the last couple of weeks.
Will check tomorrow and see what I can find!
Posted: Sat Jun 11, 2022 6:57 pm
by fpena944
Ok sort of worried and want to see if my diagnosis is correct.
Took the cover off and here is what I see:
If you look to the left that is the actual source of the leak. There's nothing running down behind it but to me it appears that this is a hole in the oil pan. Is that correct? Or am I seeing something different and jumping to the wrong conclusion.
Here is another view:
Does this mean oil pan replacement? If so how difficult? Any patchwork solutions like a JB-Weld a suitable alternative?
In any case, going to park the CTT and let wife use the Cayman and I'll rely on the 996 until we get it fixed.
Posted: Sat Jun 11, 2022 7:25 pm
by fpena944
| ! | Message from: fpena944 |
| [Idiot Mode Enabled] |
As I was securing the plastic cover under the car I realized that the screw hole for one of them lines up perfectly with the hole in the oil pan.
Then I also realized one of the screws is longer than all the others.
Yeah self-inflicted damage here. I screwed into my own oil pan!
Going to drain the oil and try some JB-Weld. If that doesn't seem to hold then a new oil pan will be in the works. Ugh...
Posted: Tue Jun 14, 2022 8:44 am
by i am not a traitor
Posted: Tue Jun 14, 2022 8:55 am
by fpena944
i am not a traitor wrote: ↑Tue Jun 14, 2022 8:44 am
I know at first I was asking my wife what she ran over. But then I got to thinking about how with the plastic covering there shouldn't be any way for a puncture without any damage to the outside.
Then I was fitting one of the plastic covers on and noticed it fit perfectly into where that hole was. Argh!
The JB Weld seems to be holding pretty well so far. I checked yesterday and it was dry. Will check again today and the day after before putting the covers back on. Lesson learned for sure!
