Stock Belt Tensioner Bolts Lenght Question
Posted: Sun Apr 24, 2022 12:51 pm
Hello,
I'm about to install the stock tensioner on my car and need new mounting bolts.
I already have the top one (that goes through the center cover).
I know that I need two M8 x 55 (left and right upper arrows).
My question is what size is the lower bolt?
What lenght I need?
I check in PET and it says M8 x 60.
60 mm is not long enough...
The pic is from Dwayne's procedure.
You can see that the longer bolt is more than 5mm than the shorter one.
Thanks!
What lenght I need?
Thanks!
