going to be a clock
Posted: Sun Apr 17, 2022 5:15 am
by h2pmr
well that's the plan
Re: going to be a clock
Posted: Mon Apr 18, 2022 7:21 am
by linderpat
Now that's a great idea! Can't wait to see it.
Posted: Mon Apr 18, 2022 11:47 am
by Hey_Allen
Hmm....
Posted: Mon Apr 18, 2022 2:16 pm
What’s great about it also…
… is that those under 35-ish won’t know what it is.
Posted: Mon Apr 18, 2022 5:40 pm
by Stepson
Worf,
ROTFLMAO!!!!
How F'ing true!!
Posted: Tue Apr 19, 2022 10:11 am
by WyattsRide
Posted: Tue Apr 19, 2022 2:38 pm
by h2pmr
thats a good point
i will have to fast rack my design and production of a carriage clock made from a cam belt sprocket before my target demographic start to pass away.....
Posted: Wed Apr 27, 2022 3:10 pm
by h2pmr
Posted: Thu Apr 28, 2022 3:56 pm
by h2pmr
Posted: Fri Apr 29, 2022 12:39 pm
by linderpat
Posted: Fri Apr 29, 2022 2:35 pm
by h2pmr
i was trying to think what was on at Carlisle this weekend as its only 25 miles from me, but i guess you don't mean the Carlisle in Cumbria, England
Posted: Sun May 01, 2022 12:19 pm
by h2pmr
so have been testing it for the last 36 hours and so far its keeping the correct time
Posted: Sun May 01, 2022 5:11 pm
by linderpat
Posted: Sun May 22, 2022 5:51 am
by h2pmr
but has turned out quite well
Posted: Sun May 22, 2022 7:21 am
by Bertrand Daoust
Very nice.
Well done.
It's perfect like that.
Posted: Sun May 22, 2022 12:44 pm
by h2pmr
Well done.
