still fixing 928ms brackets
Posted: Wed Apr 06, 2022 12:49 pm
I'm still fixing and improving the brakets that 928MS sold for their 6 speed conversions.
the problems with the bracket were:
Bracket physically hits transmission tail housing between the trans and diff
Bracket was only welded on one side where most of the pieces were fitted together. Large gaps on the unwelded side where rust was starting to form
rattle can finish was worn off on edges due to poor materials or application.
I had it sandblasted and I cut out a section of a cross tube where the contact was a problem.
If you look closely at the above picture you can see the gaps.
I found a local place that was able to weld it up and actually box it in from the top like it should have been done in the 1st place.
