That would explain the noise in the rear wheel.... (Brake shoe hilarity)
Posted: Fri Mar 25, 2022 4:04 pm
So as many of you know I have been complaining about a whump whump sound in the rear wheels for a few years now. At SITM an expert said it was probably the passenger rear wheel bearing. Ok.
However my parking brake has sucked for awhile and since I live on a hill it was time to find out what's up. So since I replaced the brake shoes 2 years ago on the passenger side with new ones I decided to do the same on the driver's side. Adjusted the driver's side to two clicks from tight on the star wheel and rear brakes still didn't work right.
So I pulled the passenger side wheel off, tried to adjust and kept hearing a grinding sound. Odd. Pulled the caliper, pulled the disc (thank you past me for putting anti-seize on the screws) and this was the results.
Zoom out a bit and we can see the problem.
Yep, that's the lower brake shoe sitting on the ground. This is the brake that self destructed 2 years ago and caused me to replace the darn brake cable. Apparently the new brake shoes suck or something, I don't know.
I might just stick the old shoes onto this wheel, we'll see. But this might have been the source of the noise as the hub turns quite quietly....
