First, Sean lemme answer your question from the Picture Thread. Yes, my barrel grommets come from the same dude. However, I've got a FISA letter telling me I can't described the mechanism through which they get to me...
One thing... those grommets come in two sizes. One size for me and a different size for everybody else.
The first time I got a set of these I noticed that the hole in the middle was sized for 'pre-89 harnesses and was too small for '89+ so, after much grumbling, hand waving, accusations that I didn't know my ass from a hole in the wall, I now get versions that have a larger (by <1mm) hole that fit well with the slightly larger harness covering on the '89+.
More on the differences later for those that don't routinely see a variety of 928 pass through their hands.
SeanR wrote: ↑Thu Aug 20, 2020 1:55 pm
So in trying to source a new/used one, not many seem to be available. Roger says nothing new from Porsche.
There is a smattering of them. A while ago I went the the various permutations and figured out which ones you could swap year to year. IIRC the ones with provision for RDK are backward compatible with pre-RDK, but IIRC the only ones available were pre-RDK NOS. And not a complete set. Like only the front-left or something like that.
I have and dissect them and see exactly how Porsche had them made and then replicate them using weather packs or Deutch connectors.
The problem with that, of course, is that you have to cut the body ABS harness and then if you ever replace brake pad, ABS, or RDK sensors you have to mod the new ones with the connector. And you have to come up with a new retainer on the hubs for the new connector body. I for one am not excited about all that.
Also, I know that the pre-'89 harnesses had no shielding. I *think* the '89+ harness have shielding for the ABS and RDK. But, I won't bet even a duplicated body part on that. So far the harness covering only degrades on pre'-89. The '89+ harnesses are all still in good shape but the rubber grommets are all shot (or will be very soon) on both versions.
Both versions can get circuit breaks inside the connectors or where the harness enters the connector.
My eyes tell me that the white (now yellow with age) barrel connector bodies are molded around the three individual pairs of circuit connections thus making it more-or-less impossible to 'splice' in a good barrel connector body on to a good harness with visually acceptable results.
The dude that makes the rubbers has made molds for the barrel connectors. As of about 2-3 years ago he was not offering all components necessary to do a DIY harness build.
Last, God help us when the '94-95s start coming down with ABS/BPW/RDK errors that are traced to the wheel wells.
