ChrisZ wrote: ↑Fri Nov 26, 2021 10:21 am
How much of a pain is it to switch them out and what percentage of the motor needs to come out to do it.
They are pretty easy when the motor's out :) except for the output hose on the pump.
However, they are just messy with the motor in. Mostly.
The supply hose to the pump: I always change that when I do a timing belt. The pump has to be loosened and moved around during a belt job and thus getting to the clamp on the rear of the pump is easy.
Whether or not it is easy with everything in place comes down to the orientation of the clamp on the pump-side of the hose. If it is oriented 'down' I have been able to get to it with a long screw driver from underneath by working through the lower control arm. You can see the clamp orientation from underneath.
If the clamp is not oriented down sufficiently then the pump/alternator cassette has to be unbolted so that you can move the assembly forward to get to the clamp.
The pump pressure hose is "fun" to get to under any circumstances.
The 86 model only has three hoses (tank to pump, pump to rack, rack to tank) and it looks like it's the tank to top of pump that is leaking. The big worry for me is the comments that the rack to tank return was an asbestos lined hose to go near the exhaust pipes, if that's not replaced properly then I might have a car-be-que.
The pressure line from the pump is the fire risk since it can spray high-pressure ATF on the headers.
The return line generally will just weep where the hose has plasticized under the hard line crimps.
Of course, if either hose simply bursts then you have a fire risk.
At this point in the life of all 928s, all hoses should have been replaced at least once already. Any that look original should be on your list of replacements. If there is cosmoline on the hard line portions where they connect to the rack then you know they are original. If they are obviously leaking then it doesn't matter how old they are.
Last, note that for the pressure and return lines you'll need 6 M14x18 copper crush washers; 4 for the pressure line and 2 for the rack return line.
https://www.belmetric.com/solid-copper- ... p-517.html
