Rear brake springs
Posted: Sat Nov 20, 2021 10:09 am
by Fadec
Are these springs on backwards? I’m thinking the longer spring, the one they have up front, goes on the adjuster
Re: Rear brake springs
Posted: Sat Nov 20, 2021 10:56 am
Those -^ are correct.
I know it seems weird.
Posted: Sat Nov 20, 2021 11:06 am
by Fadec
Thank you!
Posted: Sun Nov 21, 2021 7:07 pm
by ChrisZ
Right, remember the short spring presses against the adjuster and keeps it from moving around by itself. When you turn it with a screwdriver it snaps against the spring to the next tooth.
Posted: Mon Nov 29, 2021 9:53 am
by Mrmerlin
now that you have these figured out get a mirror and flashlight and verify the shoe anchor springs are properly fastened
look on the back of the hub carrier for a rib that faces forward,
the spring should hook it. common for these to not be properly hooked,
thus a short while later it sounds like loose parts in the hub
Posted: Mon Nov 29, 2021 5:14 pm
by Bertrand Daoust
What MrMerlin said:
