what are these parts ?
Posted: Fri Nov 12, 2021 6:15 am
by h2pmr
Re: what are these parts ?
Posted: Fri Nov 12, 2021 9:10 am
by SeanR
1. Sunroof slider
2. Sunroof Transmission
3. Backing nut that goes on the window lifting bracket, on the window.
4. No clue.
Posted: Fri Nov 12, 2021 11:58 am
by Addlight
Posted: Fri Nov 12, 2021 2:35 pm
by h2pmr
Posted: Fri Nov 12, 2021 3:11 pm
by Addlight
Posted: Fri Nov 12, 2021 3:18 pm
by h2pmr
Posted: Fri Nov 12, 2021 4:03 pm
by Gary Knox
Posted: Sun Nov 14, 2021 2:30 pm
by h2pmr
Posted: Sat Dec 11, 2021 7:32 am
by h2pmr
Posted: Sat Dec 11, 2021 9:20 am
by SeanR
Posted: Sat Dec 11, 2021 11:59 am
by h2pmr
Posted: Sun Jan 14, 2024 2:30 pm
by h2pmr
Posted: Sun Apr 07, 2024 3:05 pm
by h2pmr
anybody know what it is ?
Posted: Mon Apr 08, 2024 4:45 pm
by mr928
I've never seen one . Guessing its not 928
Posted: Mon Apr 08, 2024 5:50 pm
Nah, Phil wouldn’t do that.
RHD-only maybe.
Posted: Tue Apr 09, 2024 1:59 am
by h2pmr
thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
now thinking about it it might be something to do with the throttle pedal, but thats a guess, need to check my other S4.
Posted: Tue Apr 09, 2024 12:33 pm
h2pmr wrote: Tue Apr 09, 2024 1:59 am thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
Hmmm… it did look vaguely familiar. I will check pictures of the shell-out resto.
Posted: Sun Aug 25, 2024 2:24 pm
by h2pmr
white plastic part is sprung loaded, ignition lock maybe?
Posted: Sun Aug 25, 2024 4:25 pm
Part 2B:
