Rear compartment foam pieces
Posted: Sun Sep 12, 2021 10:38 pm
by milrad
Re: Rear compartment foam pieces
Posted: Mon Sep 13, 2021 6:56 am
by Geza-aka-Zombo
Posted: Mon Sep 13, 2021 1:11 pm
by linderpat
Posted: Mon Sep 13, 2021 10:09 pm
by milrad
Thanks guys!
Posted: Fri Mar 04, 2022 10:04 am
by bizman928
We are now re-manufacturing the rear Luggage area insulation foam pads that go under the carpet. you can find more information on our online shop here.
Rear Luggage Insulation pad set
Posted: Sun Mar 06, 2022 9:21 pm
by JMW928
Posted: Tue Mar 15, 2022 2:20 pm
by Charlie
Posted: Tue Mar 15, 2022 5:36 pm
Charlie wrote: ↑Tue Mar 15, 2022 2:20 pm
Posted: Mon Apr 04, 2022 3:29 am
by bizman928
Those Woodypeck pads look pretty good and are reasonably priced. I used Marshalls $20 yoga mats in closed cell urethane. Neither one is going to match the thick custom moulded pads in the later cars but they'll do the trick for sound deadening. Someone should make these from a mold of the originals, and maybe even infuse them with the distinctive 928 "old car smell".
Thanks Charlie.
Wonder if I can infuse some "New Car Leather" scent into them?
The foam has a scrim Faux leather coating on it so maybe that will help with the "New Look" smell?
Posted: Mon Apr 11, 2022 9:45 pm
by Charlie
Posted: Fri Apr 15, 2022 5:02 pm
by bizman928
HI Charlie.
Posted: Thu Jun 09, 2022 10:42 am
by bizman928
