Apologies if this has been mentioned before...
At present only a smattering of filetypes is available for upload. In particular NOT PDFs.
I'd like to make my 928 Inspection Guide available here. But, can't upload it directly.
I could zip,tar,feather,boil-in-oil to another format. But, I'd rather make it super easy for folks.
Ideally, I'd link to a server-local URL from my signature like I did on Rennlist.
Noted, looking into it!
fpena944 wrote: Mon Aug 17, 2020 8:14 pm Noted, looking into it!
Thanks! But it’s not so important right now that you shouldn’t get some sleep!
worf wrote: Mon Aug 17, 2020 9:37 pm
Well the good news is I enabled PDFs - was pretty easy!
The bad news is though the same issue that is plaguing us for uploading larger images is also affecting the PDF upload. So I have to get to the bottom of that and then it should fix the other file types.
Argh, spent all day on this one. So yeah throwing in the towel for tonight. I have a couple of techies researching it on my behalf. Hopefully will have resolution soon.
just made a reproduction of a 92850533300, front[…]
What is XR4Tim Working On?
Doing a ton of work on this E92 M3. All of the su[…]
928s For Sale Thread
Yes, and the edge-broken-up AC temp sensor inlet a[…]
I'll be there, just late Friday night. Anyone have[…]
