Connector to replace ABS/TPS/Brake pad sensor barrel connectors
Posted: Tue Jul 27, 2021 9:51 am
The barrel connectors are. Coming apart in a lot of cars. I found a triple sealed 6 pin twist lock connector that will fit inside the barrel connector clamp out of sight for those that are looking for a good quality connector.
Connectors are about $8 each side
Pins are about $1 each for good quality gold pins.
Total cost is about $30 per connector .
They are pretty nice pieces and Iām using them in a couple of places for my new ECU installation.
They are available @ mouser.com
