what's in your 928 roadtrip kit
Posted: Fri Jun 04, 2021 7:11 pm
by captainOCD
-full set of spare belts
-spare fuel pump
-fire extinguisher
Re: what's in your 928 roadtrip kit
Posted: Fri Jun 04, 2021 7:20 pm
by SeanR
Allen sockets and keys.
Fuses/Relays/Jumpers
Silicone tape.
LH (EZK's usually don't fail)
2 gal distilled H2O
Jug of oil (5qt)
Breaker bar and 27mm socket
Small, low profile jack.
Impact gun
Bourbon.
Posted: Fri Jun 04, 2021 9:42 pm
by captainOCD
I like the bourbon
Posted: Sat Jun 05, 2021 9:15 am
by ChrisZ
Spare fuses
Sandpaper
Posted: Sat Jun 05, 2021 9:16 am
by SeanR
Oh, best thing to put in your kit. AAA card.
Posted: Sun Jun 06, 2021 3:07 pm
by UKKid35
Posted: Mon Jun 07, 2021 7:17 am
by linderpat
It sure seems like everyone packs a ton - Why so much stuff? Are your cars unreliable? If I had to bring all those things that most are packing, I'd take a different car.
Posted: Mon Jun 07, 2021 12:38 pm
by ChrisZ
Posted: Tue Jun 08, 2021 7:03 am
by Redgt
Posted: Tue Jun 08, 2021 1:30 pm
by Stepson
Posted: Tue Jun 08, 2021 3:10 pm
by maddog2020
Stepson wrote: ↑Tue Jun 08, 2021 1:30 pm
Lol
Posted: Thu Jun 10, 2021 3:31 pm
by hessank
I also carry one of these
Posted: Fri Jun 11, 2021 9:30 pm
by Sazerac
Great thread!
My kit is a work in progress:
1/4" Stahlwille socket set
set of wrenches
long standard screwdriver
