Starter wire connections
Posted: Sun May 16, 2021 8:10 am
by Bertrand Daoust
Is this wired correctly?
I know the two big wires are good but want to make sure for the smaller one.
The small wire hole size only fits with that bolt (7 mm head) but what baffle me is that I thought it was on the other one (8 mm bolt head) but it can't be, it doesn't fit!
I want to make sure before I try to start the car.
I looked but could not find any pic of the connections.
Thank you in advance.
Re: Starter wire connections
Posted: Sun May 16, 2021 8:37 am
by SeanR
You're good. Even if you got the starter wire on the other hole, nothing bad would happen, you just wouldn't get a crank.
Posted: Sun May 16, 2021 8:45 am
by Bertrand Daoust
Thanks Sean.
Much appreciated.
Posted: Mon May 17, 2021 8:30 am
by Don Smith
Good morning Bertrand. Now that you have shown us the starter, I am kind of surprised that you didn’t paint it, and make it perfect, like the rest of your car..
Just saying. Sorry. Heck, your wife is used to missing you at the table, around supper time. Go get dirty!
Cheers
Don
Posted: Mon May 17, 2021 9:57 am
by Bertrand Daoust
I thought about it but skip it at the last minute!
Posted: Mon May 17, 2021 9:58 am
Well if we’re going to pick nits...
The zip ties should be white.
Posted: Mon May 17, 2021 12:09 pm
by Bertrand Daoust
Ho no, don't tell me I need to go back in there...
Well, I need to lift the the car to make sure there is no leaks and put back the belly pan...
Posted: Mon May 17, 2021 1:47 pm
by Don Smith
I thought the red zip ties were appropriate. I have never been a concours judge.....
Posted: Mon May 17, 2021 2:12 pm
Don Smith wrote: ↑Mon May 17, 2021 1:47 pm I have never been a concours judge.....
And *nobody* wants me to be one.
Posted: Mon May 17, 2021 3:52 pm
by Don Smith
O.K., if we are going to be picky here, why not red zip ties on red cables, black ties on black cables, and brown ones on brown cables? I used to work for Bell Canada as a business technician, and we had different zip ties for different colour cables. Simple enough.
Is there a reason for only white zip ties?
Cheers
Don
Posted: Mon May 17, 2021 4:25 pm
Don Smith wrote: ↑Mon May 17, 2021 3:52 pm
That’s what the factory used in that location. Concours judging isn’t about what makes sense...
Posted: Tue May 18, 2021 8:55 am
by SeanR
I use blue ones so I'm reminded that it was me that was in there last.
Posted: Tue May 18, 2021 9:39 am
by Bertrand Daoust
Blue... I like blue! :)
Posted: Tue May 18, 2021 10:13 am
Bertrand Daoust wrote: ↑Tue May 18, 2021 9:39 am
Posted: Tue May 18, 2021 4:09 pm
by Gary Knox
I'm going to hunt for bluish green. Any suggested leads?
Posted: Tue May 18, 2021 5:28 pm
by Don Smith
Harbor Freight?
Posted: Tue May 18, 2021 7:44 pm
by Bertrand Daoust
Gary,
Those might be harder to find...
Posted: Mon May 24, 2021 1:26 pm
by amdavid
You guys are always so helpful, thought I'd help here....
https://www.cabletiesunlimited.com/7-50 ... gLDVPD_BwE
Posted: Mon May 24, 2021 4:55 pm
by Gary Knox
WOW, these ties are even magnetic!! Put these all over your car and they will help pull the car closer to the center of the earth, increasing cornering capability. But, they might also reduce your top speed on the Autobahn if you are going uphill.
What a find! Thanks.
Posted: Sun May 01, 2022 3:49 pm
by Bertrand Daoust
While doing the cam gears change on the car, I decided to paint the starter.
I put the right zip tie this time!
Posted: Sun May 01, 2022 5:13 pm
by linderpat
Gorgeous Bertrand. You have such a special car!
