Adding high-flow cats to Ott X-pipe - need pipe diameter dimension info
Posted: Wed May 12, 2021 8:56 am
I have an Ott x-pipe installed on my '85 (no cats) and I would like to modify it to include high-flow catalytic converters w/o adding my air pump back. My plan is to cut/shorten the X-pipe downstream from the X section and add the individual cat units between the shortened x-pipe and the stock exhaust, keeping the stock exhaust from there to the back of the car.
Does anyone recall the dimensions of the Ott x-pipe? I want to make sure I get the right diameter size hi-flow cats to fit the shortened x-pipe. I'm also trying to remember whether the down stream exhaust pipes fit inside the x-pipe connection, or if the x-pipe fits inside the down stream exhaust pipes. I don't have pictures (and I'm being lazy about climbing under the car).
