Intermittent Headlights
Posted: Tue May 04, 2021 1:41 pm
by UKKid35
My headlights often fail to raise and switch on after the car has been left idle for a few weeks
This inevitably happens when I check the car over just before its annual MOT test
They usually come back to life within a few hours without me actually doing anything, so I've never investigated further
Any suggestions where I should look first?
Re: Intermittent Headlights
Posted: Tue May 04, 2021 3:02 pm
by Schocki
If your relay is still original, I would go ahead an replace it. Not cheap but the most common issue with our headlights.
Posted: Tue May 04, 2021 3:30 pm
If not relay, Ignition switch also leads to wacky light behavior.
Need more details on behavior.
Lights raise but don’t illuminate? Illuminate but don’t raise? Do nothing?
Posted: Wed May 05, 2021 2:17 am
by UKKid35
worf wrote: ↑Tue May 04, 2021 3:30 pm
Thanks - Do nothing
But eventually raise and switch on if I operate the switch some time later, while the engine is running
Posted: Wed May 05, 2021 7:14 am
by UKKid35
If I raise the headlights manually using the knob on the motor, they will come on when they reach the correct angle
I can then switch them off and on again using the switch, and they operate correctly
MOT just passed as they didn't embarrass me during the test
Posted: Wed May 05, 2021 7:53 am
by Fox_
I had the happen, ended up being a weak battery.
Posted: Wed May 05, 2021 8:17 am
Relay. Most likely.
Posted: Wed May 05, 2021 9:47 am
by UKKid35
Schocki wrote: ↑Tue May 04, 2021 3:02 pm
It may not be cheap, but I am, so that won't be happening
I might take it apart and spray it with contact cleaner though
Posted: Sat May 08, 2021 10:01 am
by AirtekHVAC
My car does the same thing, but opposite. New ignition switch, new headlight switch , new relay.
But , after sitting a few days, when I put mine up, they wont go down. After a couple hours of driving, they eventually just go down on their own, and start working properly again. It’s weird, and car is garage kept. Ya know it’s been a couple years since I checked the connector on the motor….
Posted: Sat May 08, 2021 10:25 am
by Fox_
Fox_ wrote: ↑Wed May 05, 2021 7:53 am
Mine would turn on, but the headlights wouldn't pop up.
Happened after sitting awhile, battery charger or letting it run awhile would fix it.
However, doesn't sound like your issue.
