Slow Sunroof: What Lubricant Should I Use
Posted: Sun Apr 25, 2021 10:51 am
by Addlight
My sunroof is slowing down again. I had repaired it several years ago, but it seems the grease I used has gotten gummy. I don't remember what it was.
What recommendations do you have for a lubricant on the cable and gears that resists drying and gunking up?
Thanks,
Matt
Re: Slow Sunroof: What Lubricant Should I Use
Posted: Sun Apr 25, 2021 10:57 am
by SeanR
Best bet is the cables that rotate are gummed up and should be pulled out and cleaned, then re-greased. Not much else you can do to make it work well.
Posted: Sun Apr 25, 2021 11:01 am
by Addlight
Thanks. yeah, I planned to pull the transmission and then the cables from the tubes and clean it all. But then what grease do I reapply? I don't want to make the same mistake I did last time and use the wrong type.
Posted: Sun Apr 25, 2021 11:07 am
by SeanR
I use a tub of lithium grease. Seems to work well.
Posted: Sun Apr 25, 2021 11:25 am
by Addlight
Thanks. I have some white lightning lithium grease I use on bike chains. It's a fairly light grease and doesn't gum up chains, so I will try that.
Posted: Sun Apr 25, 2021 2:22 pm
by Addlight
Got everything apart and cleaned and thought I would share this tip.
To clean each cable, I soaked them in Goof Off to soften up the old grease. After that, I put the end of the cable in an adjustable speed drill. I wrapped a flathead screwdriver with a blue paper towel, stuck that into the groove on the cable and then slowly spun the drill, letting the flathead push the old grease out of the groove as it spun down the cable.
I kept readjusting to fresh paper towel as a section got gunked up with the old grease.
Finally, I scrubbed it with Simple Green and a nylon brush, and the cables are now free and clear.
Matt
Posted: Sun Apr 25, 2021 2:30 pm
I found a PTFE dry spray that I’ve been using on sunroof bits.
