Solutions for S2 Fuel Injector/CPS wire Harness?
Posted: Fri Apr 23, 2021 1:12 pm
by checkmate1996
Might need solution for this depending how testing goes. The CPS female side "wires" not the connector were shot...
Re: Solutions for S2 Fuel Injector/CPS wire Harness?
Posted: Fri Apr 23, 2021 1:13 pm
checkmate1996 wrote: ↑Fri Apr 23, 2021 1:12 pm
So... the harness-side of the CPS?
Posted: Fri Apr 23, 2021 1:20 pm
by SeanR
Roger has the connectors. The trick is to make absolutely sure none of the wires come in to contact with each other when you replace the connector.
Posted: Fri Apr 23, 2021 1:46 pm
by checkmate1996
so in the meantime, I poached a couple of bosch female connectors from my parts cache. Stripped the old wire and re-soldered new connections. Doubled up on the heatshrink wrap for each wire. Hopefully that's enough...
Posted: Fri Apr 23, 2021 2:16 pm
checkmate1996 wrote: ↑Fri Apr 23, 2021 1:46 pm
It's the shielding of the harness branch to the CPS that kills ya...
Posted: Fri Apr 23, 2021 2:25 pm
by checkmate1996
Yeah that’s what I am worried about.
Posted: Fri Apr 23, 2021 2:34 pm
checkmate1996 wrote: ↑Fri Apr 23, 2021 2:25 pm
A long, long time ago I did a repair to an S3 harness CPS branch close to the connector. It worked for a while. Then another internal break appeared closer to the root (where the CPS branch leaves the 'trunk' of the LH harness.) I repaired that. It worked for a while.
Then another break appeared at the root. I threw the harness away and installed a used one.
The good news is that you can repair the shielding. You can use aluminum foil if you need a 'big' section.
The bad news is that once the guts of the harness in the air guide area shows breaks, IMO, chances are there's more than one.
Back of the motor is a tough place in which to live. For 35+ years.
Posted: Fri Apr 23, 2021 3:46 pm
by checkmate1996
