Crumpler wrote: ↑Mon Apr 05, 2021 4:49 pm
The basic premise is if I paid for a dyno run at a pro shop would the graph look the same in basic intents and purpose as the graph on the gtech?
Usually an inertial dyno will log dyno speed and the shop will hook up an inductive sender to a plug wire and a tail pipe sniffer for rpm and a/f ratio logging. From dyno speed and rpm the dyno software will compute torque, horsepower versus rpm and also A/F at rpm. This is what's called "sweep tuning" and is mostly about not blowing shit up.
A/F at rpm is pretty much the minimum you need to do any useful tuning. However, what you see from a tail pipe sniffer in terms of accuracy is like horseshoes and hand grenades: You're seeing A/F at the tail pipe many many engine revolutions after it left the exhaust valve. So, about the only thing you can do is raise or lower A/F to try to find an optimum across the range with no lean spots.
OTOH, if you can do WOT runs on the road and not getting any knock then what you've got is probably safe. But, you've no way to determine if you're getting anything like the max possible power or if you're just dumping fuel out the tail pipe when cruising. For the former you have to log A/F from at least as close as a wide-band 02 sensor near the manifold. For the latter you have to do real tuning on a brake dyno.
I’m also not seeing it lean out at WOT. So I can’t say any bad things yet.
By what mechanism do you know that you're not lean?
And for WOT what consitutes lean?
Lean for WOT is not the same as lean for cruise.
My biggest issue yesterday was trying to do a controlled pull in Easter traffic on I-270 :(
Yup.
Yes, no sharktuner yet. I would only have control over FMU and some MAF function. I have an 87 FPR, it’s not variable.
I could have, maybe, Ken make a chip to pull some timing a high end, but I’m not even there yet.
You'd pull timing if you are getting knock with a known-good A/F ratio.
Are you using Ken's adaptive timing chips? Or are those EZK only?
For actually *tuning* you need to use a brake dyno that can hold the car at chosen specific loads and rpms. You'd choose these specific values to correspond with timing/load cells in the Shark Tuner and then dial in fuel and timing for each cell. Ideally you'd also log EGT so that you can see the effect of your tuning on EGTs.
