smog pump bearings
Posted: Sat Mar 27, 2021 4:21 pm
if your smog pump is noisy, or usually has been removed as it was noisy or seized up, the bearings can be replaced.
all 77-95 pumps use the same bearings.
i have done 5 pumps now and as my day job is a mechanic they are lovely to strip and rebuild, quality is in a different league to any units fitted to today's vehicles which are none repairable.
the bearings needed are:
1x 62032RS Budget Rubber Sealed Deep Groove Ball Bearing 17x40x12mm
1x Major Branded B188 Imperial Drawn Cup Open End Type Full Complement Needle Roller Bearing 1-1/8x1-3/8x1/2 inch
4x BA65ZOH Imperial Needle Roller Bearing 3/8x9/16x5/16 inc
hope this helps someone
