Front Coilover Mounts - Or, that's where my ride height went!
Posted: Sat Mar 13, 2021 8:36 pm
Front coilover mounts ("concave washer" 928 343 047 08)
Left: '90 130k miles. Right: new
Old one's "smooshed" by about 5mm.
Re: Front Coilover Mounts - Or, that's where my ride height went!
Posted: Sat Mar 13, 2021 8:49 pm
by maddog2020
you gotta give Porsche credit. they may collapse but how many fail? even at the track. these things are built like tanks. Most of these cars are 30-40 years old now. Most of them are older than their owners.
Posted: Sun Mar 14, 2021 12:09 pm
by Crumpler
Dammit, something else I gotta check now.
Posted: Sun Mar 14, 2021 5:41 pm
by maddog2020
@ nearly $500 per side...... lots of people may wait until they are cracking. I bet replacing them probably improves the ride quite a bit.
Posted: Sun Mar 14, 2021 9:30 pm
maddog2020 wrote: Sat Mar 13, 2021 8:49 pm you gotta give Porsche credit. they may collapse but how many fail? even at the track. these things are built like tanks. Most of these cars are 30-40 years old now. Most of them are older than their owners.
Yup. Lot's of other cars need shock/strut mounts replaced frequently. The 928's just see to soldier on forever.
maddog2020 wrote: Sun Mar 14, 2021 5:41 pm @ nearly $500 per side...... lots of people may wait until they are cracking. I bet replacing them probably improves the ride quite a bit.
We shall see. But, not any time real soon. This one's still got a long way to go before first drive.
Posted: Mon Mar 15, 2021 11:01 am
by Crumpler
Are there any viable aftermarket options? Any crossover performance stuff from other period P cars?
Besides the 928 Motorsports rigmarole.
Posted: Mon Mar 15, 2021 11:57 am
Crumpler wrote: Mon Mar 15, 2021 11:01 am Besides the 928 Motorsports rigmarole.
The ones that are a solid hunk of aluminum? Those ones?
So... yaw’ll know that on the 991/981/718 the struts (not coilovers) mount metal to metal with the chassis? And that the chassis tower mounts have a tendency to break off from the rest of the inner fender when used in ‘racing conditions’ (or even sometimes from hitting a really deep pothole?)
When the wheel hub goes up and down the coilover (or Mac Strut on the new ones) bottom moves up and down. I’m not talking about the axis of shock push rod travel. The angle of the coilover with respect to the top changes: it flexes at the chassis mount. It’s a simple trig problem to calculate the angle change.
Anyway: I would never, ever want a metal-to-metal mount for the chassis and coilover on a 928. You need something that will flex between the coilover and chassis tower mount or... bang!
Posted: Mon Mar 15, 2021 2:17 pm
by Crumpler
Yikes.
Ok, that makes sense.
Posted: Mon Mar 15, 2021 5:21 pm
by maddog2020
and the older the mount the stiffer they get. I'm going to bet the steering feels much smoother when going over bumps. I may have to order a set because I've replaced everything else... can't have one old part canceling out all the new ones. besides I'm still waiting on my spindles....
Posted: Mon Mar 15, 2021 6:00 pm
GT4:
Posted: Mon Mar 15, 2021 6:38 pm
by maddog2020
worf wrote: Mon Mar 15, 2021 6:00 pm GT4:
Whoops... :hitfan:
Posted: Mon Mar 15, 2021 8:52 pm
by FlatSix
WTF????
Are they pulling an Alfa and buying surplus Soviet steel?
Posted: Mon Mar 15, 2021 9:14 pm
FlatSix wrote: Mon Mar 15, 2021 8:52 pm WTF????
As you can imagine, there is a lot of debate. Failures seem to be rare but still enough that it's a "thing." Not RMS or IMS level. Yet.
From reading some (certainly not all) of the long threads on this failure mode on the various boards, my *personal* opinion is that the failure is linked to folks that lower the ride height and/or more common for cars that come from the factory with low ride height (e.g. GT4, cars with SPASM, folks that slam their P-cars to the ground with lowering springs.) So, you get more chance of completely compressing the strut on a big hit AND the slight change in initial control arm geometry doubles the angle change of the strut relative to the mount when the wheel and hub assembly has to "rise" into the wheel well. So: significantly more bending stress on the chassis tower mount.
The ClubSport GT4s have an extra tie bar that ties the top of the strut to the fire wall so that when(!?) the failure occurs on the track the car is still controllable. AND there's a Porsche Motorsport part and procedure for replacing the mount in the inner chassis.
Posted: Mon Mar 15, 2021 9:16 pm
by maddog2020
worf wrote: Sat Mar 13, 2021 8:36 pm Front coilover mounts ("concave washer" 928 343 047 08)
Can you get a more accurate measurement since your ruler is not lined up? my 928 has spent most of its life on jackstands... so I wanted to measure how bad off they are... they are still 31 years old
Posted: Mon Mar 15, 2021 9:19 pm
maddog2020 wrote: Mon Mar 15, 2021 5:21 pm I may have to order a set because I've replaced everything else... can't have one old part canceling out all the new ones.
That ended up being the 'theory' on this resto. With Mark's Weissach pivot bushing replacements available and a set for this one already installed, those front tops were the only original piece of rubber left.
Posted: Mon Mar 15, 2021 9:22 pm
maddog2020 wrote: Mon Mar 15, 2021 9:16 pm Can you get a more accurate measurement since your ruler is not lined up? my 928 has spent most of its life on jackstands... so I wanted to measure how bad off they are... they are still 31 years old
That was to be a comparative measurement. But, yeah, I was thinking yesterday that I should measure both more accurately so that I can take measurements of 928s that roll into the shop.
So, I'll do that. Tomorrow.
Posted: Mon Mar 15, 2021 9:37 pm
by maddog2020
it would be interesting to see a cross section if you care to cut one in half. In looking at the profile I'm wondering if the new ones were made differently some aspects look really out of proportion, and while shrinkage might be part of it, It wouldn't be the 1st time Porsche changed the "formula" for new parts. Not to mention the average 928 home mechanic probably has better measuring tools than Porsche did back when these were designed.
Posted: Mon Mar 15, 2021 9:55 pm
maddog2020 wrote: Mon Mar 15, 2021 9:37 pm it would be interesting to see a cross section if you care to cut one in half.
I plan to cut an old one up. Not real soon. But, I ain't cuttin' a new one up 'less you send me one :nono:
maddog2020 wrote: Mon Mar 15, 2021 9:37 pm In looking at the profile I'm wondering if the new ones were made differently some aspects look really out of proportion,
What do you see that seems out of proportion? I stared at them for a few minutes. The studs in the new seem different.
maddog2020 wrote: Mon Mar 15, 2021 9:37 pm and while shrinkage might be part of it, It wouldn't be the 1st time Porsche changed the "formula" for new parts.
These came from Germany. Based upon discoloration and deterioration of the bag, dust, and the number of stickers, I'm betting on NOS.
Posted: Mon Mar 15, 2021 10:27 pm
by maddog2020
any dates on the stickers?
Posted: Wed Mar 17, 2021 9:59 pm
Bag with stickers is long gone.
Old smooshed mount is 74mm at the point where the spring terminates. This is the easiest place to measure with the mount installed.
New mount is 5-6mm taller.
Posted: Wed Mar 17, 2021 10:11 pm
by maddog2020
between this collapsing and springs aging this might be why some cars are on the bottom of the adjustment threads trying to get cars level. great find~!
Posted: Wed Mar 17, 2021 10:16 pm
maddog2020 wrote: Wed Mar 17, 2021 10:11 pm between this collapsing and springs aging this might be why some cars are on the bottom of the adjustment threads trying to get cars level. great find~!
'tis an easy measurement to do. Can do it with everything installed. I did it, but couldn't take a picture of me doing it.
So, we could gather data from the fleet: model year, mileage, top mount height...
Get enough data points and we might get an age/mileage/height surface plot.
Posted: Thu Mar 18, 2021 4:02 pm
by AirtekHVAC
Wow! I would have never thought that. This would explain why new shocks did not help the front of my 82. I reused these mounts. They looked ok....perhaps this will make the difference!
Posted: Thu Mar 18, 2021 4:53 pm
by checkmate1996
I just happen to be doing my shocks after finding out one of my front konis was hosed. This is very timely information. Thanks for sharing...
Posted: Fri Mar 19, 2021 3:20 pm
by checkmate1996
1985 - 97000 miles - Sat for a long 15 years - Driver 71.63mm Passenger 74.44mm. Worse than your measurements but no budget to replace at this time so I have to go with it. Overall, they LOOK ok but clearly that's all they got going for them... :bigcry: :cussing:
Posted: Fri Mar 19, 2021 4:06 pm
checkmate1996 wrote: Fri Mar 19, 2021 3:20 pm 1985 - 97000 miles - Sat for a long 15 years - Driver 71.63mm Passenger 74.44mm. Worse than your measurements but no budget to replace at this time so I have to go with it. Overall, they LOOK ok but clearly that's all they got going for them... :bigcry: :cussing:
Don’t :bigcry: over it just yet. What we don’t know is how much new mounts settle in the first bit.
But, of course, we do suspect that new rubber is ‘more-rubbery’ that 30- to 40-year-old rubber.
Posted: Sat Mar 20, 2021 2:20 am
by The Fat Man
Sheet.
One more thing to worry about selling a kidney to replace when I take the front shocks apart. Again.
Posted: Fri Jul 02, 2021 9:54 am
by Gary Knox
Anyone installed the new ones and driven the car at least a short distance to see how much the new upper mounts compress?
By the way, Delaware Porsche has them on their web site for ~$270 each. https://www.delawareporscheparts.com/oe ... dhcw%3D%3D
Posted: Fri Jul 02, 2021 12:38 pm
by maddog2020
not yet. however the center bushings should be replaced as well. With them being new, I don't expect them to compress much. I could be wrong.
ymmv
Posted: Fri Jul 02, 2021 1:05 pm
Gary Knox wrote: Fri Jul 02, 2021 9:54 am By the way, Delaware Porsche has them on their web site for ~$270 each.
Yeah, that’s about what one should expect. The rear mounts are/were cheaper IIRC.
Posted: Wed Oct 12, 2022 7:10 pm
by Tony
https://www.getporschesilverspringparts ... 2834304707
229?
only piece of rubber i have not replaced underneath..now it bugs me. :roflmao:
Posted: Wed Oct 12, 2022 9:16 pm
Tony wrote: Wed Oct 12, 2022 7:10 pm https://www.getporschesilverspringparts ... 2834304707
229?
That's the 07 old number. If SSP actually has those on a shelf, buy two. Ask them how many more they have on a shelf at that price and let me know.
The 08 part which replaced it is $298.
Posted: Wed Oct 12, 2022 9:44 pm
by Gary Knox
Do we know when the 08 version was introduced? If only a year or two ago, then the 07's should be good. If 10 years, the rubber in those will not be as pliable as the 08's.
Posted: Wed Oct 12, 2022 10:03 pm
Gary Knox wrote: Wed Oct 12, 2022 9:44 pm Do we know when the 08 version was introduced? If only a year or two ago, then the 07's should be good. If 10 years, the rubber in those will not be as pliable as the 08's.
No, not really. I’d guess that it was ‘19-ish. I ordered 07s in ‘20 and got 08s.
Posted: Sat Oct 15, 2022 11:48 pm
by jschiller
I just ordered two sets, one from Silver Spring and one from Circle Porsche (@219 ea). Lets see if either deliver. If both orders come through, I will offer a set here.
Posted: Mon Oct 17, 2022 2:00 pm
by jschiller
Both orders were cancelled, saying the part has been superseded by the -08 version. Oh well. The good news is that RosePassion has them [allegedly] for 512.05 EUR a pair with shipping to the US. With the euro down, that worked out to $501.91. Not too bad.
Posted: Mon Oct 17, 2022 2:15 pm
by SeanR
jschiller wrote: Mon Oct 17, 2022 2:00 pm Both orders were cancelled, saying the part has been superseded by the -08 version. Oh well. The good news is that RosePassion has them [allegedly] for 512.05 EUR a pair with shipping to the US. With the euro down, that worked out to $501.91. Not too bad.
Did you check with Roger first?
Posted: Mon Oct 17, 2022 2:28 pm
by jschiller
SeanR wrote: Mon Oct 17, 2022 2:15 pm
No. I didn't see them on the site (I know, I know, you have to call him) so I just went with Rose Passion. I'd be shocked if the were any less anywhere right now.
EDIT: Just got confirmation they were in stock and DHL says they are on the way.
EDIT: Got 'em. Delivered yesterday. I don't think you are ever going to find cheaper so you better stock up now. :jumper:
Posted: Wed Aug 07, 2024 5:48 pm
by Benno
I wonder if anyone has have cut a cross section of one of these so we can better understand how they are made. It would seam the rubber could be replaced.
