Rear quarter glass trim installation
Posted: Thu Feb 04, 2021 4:39 pm
87s4
seal is on the glass fine and the trim went in easily with some soapy water on the barbed trim piece as well as in the channel it slots into.
The issue I'm have is getting it all to the correct installtion spot on the rubber seal. At the ends there has to be enough trim left over to slide into the corner trim pieces. At this point it has just been trial and error and i always end up with a gap at either end. Im to the point where the gaps are even though.
I assume when the seal is installed in the car it compresses up against the glass and effectivly reduces its length and the trim parts “should” meet with the required overlap they need
Really only have one shot at doing it right which is why in thinking about putting the window in first then adding the trim with soap in the groove and pushing it in. Ive read success stories both ways....trim on...and trim off during rear quarter glass installation.
tips..ideas...
(The corners will be repainted to match )
tips..ideas...
