Power window limiter / stops
Posted: Wed Jan 27, 2021 2:50 pm
Looked on PET and cant seem to find a reference to this. Two on each window and basically limit the upper and lower limit of travel on the window mechanism. They are plastic blocks that sit inside a part that bolts to the window drive.
mine are in shambles.
i have an idea how to fab up my own. I have some very hard rubber jacking pads that came with my quickjack...i could sacrifice part of the extra one i have.
are these parts available though.???
also, i found that the retaining bolt on this to be loose on both windows. This will cause the window to go beyond a normal limit and cause the door frame to flex. I saw someone make reference to that issue recently...cant recall what thread. But, this is most likely the problem causing it.
